CVCashmere
- Mar 28, 2017
- South Jersey
- Carl
- 15 GT Vert w/Steeda lower brace, PP sways & susp
If you have a GT from 2015-2017 and want it to handle better, here is a complete set of Performance Pack springs that can be installed by a shop. They came from a 2016 6-speed coupe and are identical to my other set from a 2017 6-speed coupe. They were used less than 2 years. The ride height should remain similar. The convertibles are heavier and have different springs.
These springs were an upgrade from the standard GT springs and were not even available for the convertible in 2015.
Since I have 2 identical sets, I am selling the extra set at an extremely attractive price to make room in my garage. If your shocks are older, I recommend that you install new stiffer shocks that can handle the stronger spring. They are in excellent shape and used less than 2 years. If you have an Ecoboost, these springs will probably make your front end sit too high unless you cut them to match.
They are too heavy to ship, but can be picked up in Medford, NJ (just outside of Philly). Enjoy your improved handling!
The front set: S550 FRJ FR3C-5310-JD E29ES
The rear set: S550 FRJ FR3C-5310-JD Q48PA
See spring rates below:
Front/Rear
GT stock: 160 / 668
GT PP: 165/728
Thanks for Looking!
CVCashmere
Front/Rear
GT stock: 160 / 668
GT PP: 165/728
Thanks for Looking!
CVCashmere
