BrettT
- Apr 20, 2018
- Richmond, BC
- Brett
- 2019 Bullitt, 2006 Jetta 2.0T, 2013 Escape SEL
You are not providing much info to go on. So you are saying the car will not reach redline? What gear are is this in? The car will not redline in 5th or 6th. If you are in any gear lower than 4th, redline should arrive arrive quite quickly. Also, someone correct me if I'm wrong, but in Europe, you have 3.55 final drive. With the 3.73 final drive, the car hits the speed limiter at redline (263 kph@7,400rpm), so I believe that with the 3.55, you will hit the speed limiter before the rev limiter in 4th. So you will only be able to hit redline in first to third gears, not 4th, 5th or 6th.I don't think the debate was due to the overall performance of the car, but if that (my car) behavior was normal, and it wasn't... but after have analyzed it, as I specified in a previous post, probably because of the high temperature and stressed clutch (it's just guessing as I have no log to analyze). The engine doesn't push up to the red line, and it couldn't (due to its nature), does it has enough power up to the limiter, of course.. it's a damn 5.0 V8 with 460hp stock, surely it doesn't stop after reaching the peak torque and power, it just perform worse.
If none of the above applies, you should probably take it to the dealer and have then look at it.
