DFB5.0
If you are really into washing your car, you will most likely want to have a pressure washer setup that is tailored to the task at hand. The gun and wand supplied with all pressure washers are bulky and too long for ergonomic and efficient car washing. This is where upgrading to a couple of key items will transform the user experience.
I have been running MTM gear on my Kranzle pressure washer since I took delivery of it last year, including the SGS 28 short gun, wand and nozzle tips. While I have added these to a pretty high end machine, these parts can be adapted to most pressure washers on the market.
Having used these items for a while now, I wanted to make a couple of key improvements of my setup.
The first was a new wand, the Obsessed Garage spec Mosmatic wand.
https://www.obsessedgarage.com/coll...ts/mosmatic-og-spec-stainless-steel-bent-wand
Compared to the MTM wand, pictured at the bottom of the above pic, the OG spec wand is lighter, has better quick connects and a soft touch grip instead of the hard plastic.
The OG wand also has no rubber protector fitted as this role is left to the next item, OG spec Mosmatic nozzle tips.
https://www.obsessedgarage.com/coll...ns/products/complete-mosmatic-nozzle-assembly
These OG Spec Mosmatic Nozzle tips are shrouded in a rubber boot to prevent damage if, for some reason, it doesn't seat in the quick connect socket. I ordered both 25 degree (for wheels) and 40 degree (for bodywork) tips.
Compared to the MTM tips, the OG spec items are less fiddly and therefore easier to put on the gun and remove when swapping over to the foam cannon. They also have a more defined output, especially the 40 degree tip.
As mentioned, these items can be adapted for use with most pressure washers, and while expensive, will most likely outlast the machines they are attached to.
Only problem now is I want the OG spec Mosmatic gun too.
https://www.obsessedgarage.com/coll...pec-high-pressure-sprayer-w-quick-disconnects
