MMR / ARP Head Studs kit for 2013-2017 11mm Ford 5.0 Coyote
Mod Mustang Racing
California
www.modularmotorsportsracing.com
Worlds Fastest & Only 5 second Coyote
MMR is known for building the strongest components for the 5.0 Coyote Engine and this headstuds kit is no different. A must for all Power adder vehicles. Manufactured under strict ISO 9001 Standards. Includes 20 MMR Studs & Washers & 20 ARP Nuts with packet of ARP Moly Lube to complete installation on 1 engine (2 heads).
Features:
MMR Studs USA Made from Premium 220,000+ Tensile Strength Alloy
ARP Nuts
ARP Moly Lube
MMR Studs Feature Allen Wrench provision on top for easy installation
Fits:
2013-2017 Ford Mustang GT and F150 (11mm Diameter)
Does Not Fit Applications that use 12mm Diameter
Instructions
Install Studs into Block hand tight
Always use new Head gaskets & Dowels Install cylinder heads
Install Washers
Lubricate exposed portion of threads with Supplied ARP Lube
Starting from Middle Working toward outside
Torque in the following Steps (never use a impact wrench):
Step 1 50 Ft lbs
Step 2 75 Ft lbs
Step 3 95 Ft lbs (Final Torque Value)
Advertisement
207 - CSWC
Advertisement
