MMR 600 wheels pics on cars
MaskedRacerX
Driver
Vilano Beach, FL
DT
19 Mustang GT convertible, Orange Fury + Ebony, A10/PP/AE/MS/B&O
I'm running the 20x10/20x11 with a 285/305 tire combo, it's perfect. In fact, I like these wheels so much, I'm swapping them onto a new Mustang and selling my old car with stock Perf Pack wheels.
Advertisement
#1Roadking
Loudon N.H.
Joshua
2019 Mustang GT 2019 Ford Raptor 2018 Cadillac Escalade
  • Thread starter
  • Thread Starter
  • #18
Ok here’s my thoughts, 20x10 35mm offset satin black M600 with PS4S tires in 275x30 front and 20x11 50MM offset with PS4S in 305x30 rears. Sound like a winning combo? Slightly shorter (.6 inches front and .5 inches rear) overall height then stock is my only concern.
2morrow
DesignR/DriveR/RiceEatR
NorCal Bay Area
Todd
'16 Mustang GTPP
Doooo ettttt!:like:
DarrenMRRWheels
Commerce
2015 S550
19" or 20" M600 are in stock now. Both finishes......
Thanks
Darren
MRR Wheels
MaskedRacerX
Driver
Vilano Beach, FL
DT
FWIW, in the pic above, I'm running a 35 series, front and rear, I thought it filled the fender a touch better (and they're a little more compliant). Aslo, a 285 and 305 with the same profile are exactly the same front-to-rear ratio as my stock Perf Pack wheels - there's not any issues with the slightly different setup with the 275, but a 285 is also a little better fitment on a 10" wide wheel.
Just my $0.02 :)
#1Roadking
Loudon N.H.
Joshua
  • Thread starter
  • Thread Starter
  • #22
I can’t get the tires I want in a 35 or I’d be all over it. The PS4s tires work really well in all non winter conditions and don’t need to heat up a lot for good grip. I can get them in a 285x30 though and that brings the height up to almost the stock height! Maybe I should do that. I’m just worried about tram-lining. My ZL1 had 295 fronts and it tram-lined really bad. I’m eventually going to put Upgraded suspension on and lower it about an inch.
#1Roadking
Loudon N.H.
Joshua
  • Thread starter
  • Thread Starter
  • #23
Ordered ended up with the 285/30’s for the front. $2750 for everything mounted balanced with tire pressure sensors.
Not_Reza
Reza
'19 GT PP1
Thanks
Darren
MRR Wheels
I'm in the process of buying a set of 19x10 +35 and 19x11 +50 M600 through a company called Fitment Industries. I'm planning on running 285/35 and 305/35 on them, but their rep said that tire setup might be too aggressive and require fender modification. Do you guys know if that is or isn't the case? I am on steeda sport progressive lowering springs
2morrow
NorCal Bay Area
Todd
'16 Mustang GTPP
I think you'll be fine.
A 285 on a 10" wheel is as far as you want to push it but it will drive and look good.
2morrow
NorCal Bay Area
Todd
'16 Mustang GTPP
And yes, someone will chime in about running a 305 on a 10 but the bulge will have negative handling performance effects.
Can you do it? Yes. Will you be maximizing the performance of your tires and ultimately what you spent? No.
2morrow
NorCal Bay Area
Todd
'16 Mustang GTPP
Would a 275 be more appropriate?
Up to you and how you plan to use your car. I run an exact set up and it handles great (RE-71R).
You might be able to find 275 that are slightly cheaper. Every tire is different and I would suggest
looking at the measurement at TireRack and comparing to the width of your wheel.
I always recommend having people that are shopping and not too sure to read this great article
by racing and mustang guru Billy Johnson. It really brought a much more comprehensive thought
process to fitment and application for me and a lot of my mod friends.
https://motoiq.com/how-to-properly-select-and-size-tires-for-performance/
Good luck and let us know what you go with!
samd1351
Olathe, KS
Sam
2017 Mustang GT, 1999 Ranger
not 19's but same wheel 20x10/20x11.
Damn that looks nice! I would love to do something similar, maybe with just a hair darker.
Advertisement
4 - Big Worm Graphix
Advertisement
