Spikertg
- Jul 29, 2021
- stillwater OK
- Tyler
- 2018 Mustang GT
2018 base GT 6spd manual
TSP 1' 7/8 long tubes catless
N2MB WOT BOX
Ben Calimer stage 1 Mt-82
Centerfource SST
Pmas intake
Oil separator
clutch line
PBD e85/93 tuned
Problem:
Hi, I am slowly going insane trying to figure out why this is happening please help. Experiencing a miss or timing reduction at higher rpm (mostly above 4k) but random. This problem happened on a leisurely drive where the car started to stall and kept entering limp mode with the wrench light, so I assumed plugs, drove it home and did plugs and it changed to only under high rpm but no limp mode. Besides the clutch and flywheel 2,000 miles ago nothing including the tunes has changed or acted up on the car for months, and nothing like this. Always happens if I get on the gas, the car seems normal but sluggish and breaks up. NO lights on the dash indicating a miss or anything while it happens, tried with traction on and off and unplugging the relay by the air filter same result. the car just got a counterforce clutch and flywheel a month prior, the problem didn't occur until the day after the first night I drove the car hard.
Also, I have a few codes but most of them go away on my normal tunes the most common two are P0630
and U0422 ( did research and found those are usually related to a rear gear change and mine are stock and have not changed in my tunes.) The car had a P0315 code but I got rid of that with a crank relearn, occasionally the car will show a service advanced track screen on the dash after flashing but always goes away.
Attempted solutions:
I didn't do the crank relearn until after this problem started but it did do away with the crank error code( P0315) otherwise no help. I thought the WOT box might have had a wire loose but I not only resoldered and checked every connection for it, but I also disabled it and the problem is still here.
I just did a new set of NGK plugs thinking that was the problem but it did not help, even pulled them out again and checked the gap (.054) and spark on each one.
I have some logs of this problem it looks like the car is dropping timing from 30+ degrees normal to at most -5 when the miss or power cut occurs.
I also noticed "throttle angle actual "is fluctuating in the log when this happens, so I removed and cleaned my throttle body and checked connections, also cleaned the MAF with the correct cleaner with no change.
As usual, tuners are being no help so any input is appreciated, can attach what logs I have.
N2MB WOT BOX
Centerfource SST
Pmas intake
Oil separator
clutch line
PBD e85/93 tuned
Problem:
