mini resonators for rasp....
yote41
pa
16 gt
thinking of adding the dynomax mini bullet resonators to my setup
kooks o/r lts with corsa extreme.love everything about the setup except the sharp cracking rasp around 2800rpms
i was looking at the dyno max mini bullets. they are only like 5 inches. thinking it will help with rasp without making it to quiet. will adding these create any kind of drone?
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
H-pipe & stock mufflers. There's your 1970 Boss 302 'thump thump' idle, and a deep roar rowing through the gears @ 7k plus.
yote41
pa
16 gt
? not sure how that relates to the topic
WildHorse
N/A or GO HOME
'17 S550
You have an x-pipe and corsa correct? mini bullets are straight through muffler. used the mini bullets before, drone big time, but cuts the sound a few DB's
yote41
pa
16 gt
yea double x with extremes. not will to add drone to the setuo lol
Mustang_Lou
Toronto, Canada
2020 Mustang Bullitt
It won't ADD drone but it may not reduce it as much as expected.
Mixedup
Tampa
My shop also said the same thing on resonator add to my ARH setup hoarder catless back system. We added hig performance cats, BEHNID the o2 sensors, ahead of the H pipe. Really helped cut the "edge" or rasp I wanted ..... still loud when I hit the gas
yote41
pa
16 gt
i dont mind alittle rasp but if i can take the edge off wo adding drone im in
zuki_dan
North Carolina
15 Mustang GT Premium M6 TY
I just installed them on my car in place of the high flow cats. They reduced the catless raspy/metallic exhaust sound and the tone changed to slightly deeper under light throttle. Overall sound level is about the same as having the cats with my corsa sport catback. It still screams at WOT though.
I am still considering adding some 18" resonators to the mid pipe section.
svostang
North Texas
Tom
2015 Roush Stage 3
I just installed the vibrant 1792's on my 2015 Roush. After I added the ford performance x-pipe with side exhaust the rasp was horrible. These removed all the rasp but volume stayed about the same and still a very light drone on the highway.
ahl395
Allan
It may help a little but probably wont make a large difference. From what I gather, resonators are better the longer that they are.
I have read good things about Vibrant, and am going to be removing my cats and replacing them with 12" vibrant resonators. Hoping they will do the trick.
So the mini 6" ones will probably help a little, but if you can fit longer resonators I would do that.
