Yea the R spec wheels need to show up soon. The PSC2s are about $500/set more than R7s and not quite as sticky. Will be a limiting factor on the number of events I'll run. There's a NASA event at RA third week of May I'd like to hit for Time Trials, but not sure I want to wreck a set of PSC2s every weekend.Wow. Big $$ for bald tires lol.
The way they came apart on the track, I don't miss them a bitR compounds are super glue on the track, miss my Corsa R comps I had on the Boss 302 Laguna Seca.
I agree but that's all in the BCM and I'm sure the only one who can do this is ford / ford performance. That would be nice though.Yes, tires are going to close the gap but people are forgetting about a couple things.
Boss302s...GT500s...all had specific ABS/stability control specs. I'm certain the R, with it's sticky tires, is going to have it's own ABS and now, Magenride calibration meant to take advantage of those tires. Someone should spend some time figuring out how to bring the R calibrations for these over to the non-R - that's going to allow you to take more advantage of that new rubber and lighter-than-stock wheels. The FR500 ABS module was popular for this reason, it took into account the grippy'er tires.
A nice to have but not critical. I ran the Boss for 5 years on Hoosiers and Hawk DTC70s with the stock ABS module and rarely triggered ABS. I had the module but returned it because they reprogrammed them for off road use only and you had a complete Christmas tree on the dash for the street. If you got a very early one they programmed it without that feature before the lawyers got involved. Many guys running the module had excessive rear brake intervention that was upsetting the car. In all cases, rear pad and rotor wear went up dramatically. So the results were mixed. Yes the MR calibration will be different, but again realistically many Rs will be on R spec aluminum wheels due to the cost and abuse of extra sets of track wheels and they will also be on slicks or R7s. In that case the R MR calibration wasn't specifically programmed for those wheels and tires.Yes, tires are going to close the gap but people are forgetting about a couple things.
This is true. Me on my other car... switched from MPSS to Cup2's and my handling + lap times were clearly faster. Every track. I expect the same when I go with stickier compounds on the 350.It's speculation but I do suspect that the same experienced driver would notice a significant difference between an R and a non-r on the same sc2s.
The biggest difference is the driver. A good driver in a base would out run an average driver in an R any day any track.Agreed! By far the biggest advantageous difference is the wheels and tires.
Next weekend they'll be on and the weekend after that they'll be toast.....Has anyone put SC2 Wider tires from the R on the non R stock wheels? It's only "by size" 10mm wider so it should fit fine. I can't image there being a cards shape issue or sidewall stiffness issue.
As for all the comments about R vs. non-R. Only thing that will make appreciable difference will be tires. All other changes will net such minor differences in time that at a novice level you would not be able to differentiate it. Pros can turn laps consistent enough to find a couple tents but not us mortals.
