Metal Shavings in dipstick?
Discussion in 'Issues, Repairs, Warranty, TSB, Recalls' started by stangpede, Jul 10, 2019.
  1. stangpede
    stangpede Well-Known Member
    Vehicle(s):
    2015 Mustang GT / PPP
    Oct 12, 2017
    California
    59
    Just like the title says ...
    I have a stock 2015 mustang GT PP with only minor suspension mods.
    45k miles.
    I’ve done my own oil changes and couldn’t notice shavings in the pan when I drain it.
    But every time I pull the dipstick in and out, I notice a “scratchy” or “scrape” sound right on the bend of the tube.
    I assume my next step should be sending a sample of my used oil to a lab, but I am curious if anybody else has ran into this situation and if the dealer warrantied it . I bought an extended warranty.
  2. StangTime
    StangTime Well-Known Member
    First Name:
    Todd
    Vehicle(s):
    19' GT PP1 Manual, 14' Fusion SE
    Apr 16, 2019
    Ontario
    270
    200
    0   0   0
    You're just hearing the dip stick rubbing against the tube. No metal particles in your oil, then nothing to worry about. Send in an oil sample if it will help you sleep at night. :handshake:
  3. OP
    stangpede
    Vehicle(s):
    Oct 12, 2017
    California
    59
    I really want to believe this, but i’ve tried re-creating the sound around the tube and couldn’t. It sounds like metal rubbing on sand ha.
    If it’s common and every Mustang sounds like so, I will be so relieved. But yeah I plan to send in a sample of my oil on my next change.
  4. StangTime
    First Name:
    Todd
    Vehicle(s):
    Apr 16, 2019
    Ontario
    270
    200
    0   0   0
    Yup. Mine makes the same scraping noise going through the tube too.
    stangpede likes this.
  5. usgiorgi
    usgiorgi Well-Known Member
    Vehicle(s):
    2018 Charger Scat Pack
    Jun 22, 2016
    Fairfax, va
    637
    135
    Rating:
    100%
    1   0   0
    Wait, do you actually see metal shavings on the dipstick, or are you just saying that the dipstick is making a metal sound when it rubs against the tube?
    If it's the latter, it's obviously normal because... metal to metal contact.
  6. OP
    stangpede
    Vehicle(s):
    Oct 12, 2017
    California
    59
    Just sound. But the dipstick end is smooth and it doesn’t sound like a smooth scrape. It’s sounds like sands in there ha or metal shavings.
  7. usgiorgi
    Vehicle(s):
    Jun 22, 2016
    Fairfax, va
    637
    135
    Rating:
    100%
    1   0   0
    If you want to ease your mind, you can pick up a boroscope from Amazon for ~ $20 and put it down in the tube. But I think you're being a bit paranoid.
Loading...
Share This Page
