Steve@CJPP
- Nov 15, 2012
- Harrisburg, PA
- Website
- www.cjponyparts.com
- 2016 Comp Orange GT Prem PP
Maximum Motorsports MM6CC-10 Mustang Caster Camber Plates 2015
Lowering your 2015 Mustang will likely cause the top of your front tires to lean in towards the center of the car, resulting in negative camber, causing uneven tire wear. This can easily be correct by ordering these Caster Camber Plates from Maximum Motorsports. The OEM version of the 2015 Mustang has no provisions for camber or caster adjustment, so installing these plates will provide a significant upgrade to your new Pony.
Features:
- Adjustment for Your Camber and Caster
- 1.75-Degrees Continuous Range of Camber Adjustment
- Main Plate is Precision Laser-Cut from High-Grade Alloy Steel
- Standard Durable Black Powder Coated Finish
- Made in the USA
- Yield Strength of 100 KSI
- Retains Stock Strut Dustcovers
- No Drilling or Cutting Required
These Caster Camber Plates from Maximum Motorsports will allow you to properly align the front tires of your 2015 Mustang, especially if your S550 is lowered. Maximum Motorsports incorporates an innovative design the makes for the ability to adjust the camber setting of your front tires. These plates provide 1.75 degrees continuous range of camber adjustment.
These plates have a unique construction and are 100% made in the USA. The main plates are laser-cut from newly available high-grade alloy steel. This creates more strength to your wheels and will greatly reduce the possibility of bending. Maximum Motorsports completes these plates with a standard durable black powder coated finish. The plates will retain the stock strut dustcovers and are also designed to bolt on, so no drilling or cutting will be required to properly install.
Benefits:
- Sets Proper Front Alignment
- Promotes Even Tire Wear
- Lowered Mustangs can be Aligned to Factory Specifications
- Negative Camber may be Increased for Competition
- Improves Steering Response & Dynamic Alignment Stability
- Corrects OEM Production Tolerances
- Reduces the Possibility of Bending
- Eliminates Deflection
- Long Lasting Protection
- Increases Strength
These plates will properly set your front wheel alignments on your Mustang and will allow your lowered Pony to be aligned to factory specifications. You'll be able to adjust the camber setting to allow the reduction of excessive negative camber that is caused by lowering your Mustang. This will improve how your tire wears on the street and will also provide more grip while hitting the corners. These plates will also improve the overall steering response for when you are pushing your Pony hard.
These plates will also provide a small range of adjustment for your caster, which is otherwise not adjustable. While the 2015 Mustang chassis was created with a proper amount of positive caster for high-performance driving, it can still be a significant asset to fine-tune this adjustment to reduce any negative effects caused by OEM production tolerances. Installing these plates on your new Mustang will also provide long lasting protection for your alignment, while increasing its overall strength for a significant upgrade on your S550.
There are lots of choices for new 2015 Mustang parts. Many brands claim to have the highest quality and the best design, which translates to the superior performance. Few have the patents to prove how well engineered their parts are like Maximum Motorsports. CJ Pony Parts offers dozens of aftermarket Mustang parts from Maximum Motorsports that truly are the best on the market.
Order these Maximum Motorsports Caster Camber Plates for your 2015 Mustang from CJ Pony Parts today!
See more Caster Camber plates from CJ Pony Parts here:
Mustang Caster Camber Plates | CJ Pony Parts
See more from Maximum Motorsports from CJ Pony Parts here:
Maximum Motorsports | Ford Mustang Parts | CJ Pony Parts
For the install video of this item check this LINK
