gte
Ironically, you've accurately described your last couple of posts in this thread, when you said "totally useless post". I quoted everything that you wrote that was wrong, which was everything that you wrote that I quoted. Had you quit after the initial post, you'd have been fine.
It started when you tried to narrow your response to a set of environmental limitations that the original questioner did not specify, and it was said after the fact as a defensive response to you being corrected about the choice of adjectives that you used ... in the particular case you used the word slight, a gross under exaggeration. There was also some talk about you applying your own driving situations and money situation as a variable as to why you answered the questioner the way you did, assuming that his circumstances were identical to yours, same type of mistake as above. You also decided you would speculate on how much power you were losing and saying that you speculated it "wasn't that much" .
After that you psuedo acknowledged a tuners knowledge, but then qualified the acknowledgement saying that his only experience was at wide open throttle, and his area of expertise was not in the scenario of daily driving. <--- that actually had to be the dumbest thing I've read in this diatribe and was the icing on the cake.
All of that, speculative nonsense at best. I'll tell you what, if you don't believe a tuner that has continually logged and tested the parameters you are speculating about, then you can come to my house and we will put your MEB on my dynojet in my home garage and I'll show you how badly heat soak and an inadequate intercooler can affect performance.
You did at least say one thing that was accurate in the latter posts, which is quoted below ... but you must not have felt bad because you continued doing so with each keystroke.
Your biggest problem is that you suffer from the Dunning-Kruger Effect and I'd imagine that affects all parts of your life, not just your forum persona ;)wmsky said:And yes Kazy, I feel bad that I'm blowing hot air
And this is a beautiful example of a totally useless post. I am speaking about what I know. Put up or shut up. Tell me where I'm wrong.
