MAPerformance: Ultimate R&D Thread | Air, Fuel, & Turbo Upgrades
Discussion in 'I4 2.3L EcoBoost Engine / Mods: Bolt-ons, Exhaust,' started by MAPerformance, Feb 18, 2015.
  1. AngelOreo
    AngelOreo Well-Known Member
    First Name:
    JimmyG
    Vehicle(s):
    2015 - Ecoboost Premium - 6mt - Deep Impact
    May 11, 2015
    Delaware
    129
    Silly question perhaps...
    Do the rods weaken over time or do they typically break when stressed plain and simply. At 500-550whp, the Rods may switch to a room with view quickly, but would they eventually tire at 400whp then go? Is this still controlled by how the torque is delivered or does it just go splat regardless at some point?
  2. cosmo
    cosmo Well-Known Member
    Vehicle(s):
    2005 Mustang GT
    Sep 22, 2014
    Michigan
    1,770
    764
    0   0   0
    http://en.wikipedia.org/wiki/Elastic_modulus
    So, basically there is a window where the material can take the load, without an issue. Any material change has the capacity to be reversed, until a certain point. See this graph:
    [​IMG]
    After that elastic limit, the material can't go back, and that's when damage occurs up to the moment of breaking. The difference between the yield point and breaking point changes depending on the material. Seeing as these rods are a type of forged metal, this leads to something with low ductility and high strength. Low ductility leads to a shorter distance between yield point and breaking point, so when it goes, it will go pretty quickly.
  3. AngelOreo
    First Name:
    JimmyG
    Vehicle(s):
    May 11, 2015
    Delaware
    129
    That is really good info! Thank you.
  4. OP
    MAPerformance
    MAPerformance Well-Known Member
    Gold Sponsor
    First Name:
    Sales
    Vehicle(s):
    2015 Ecoboost Base w/ Performance Package
    Jan 14, 2015
    Cottage Grove, MN
    1,680
    997
    Rating:
    100%
    1   0   0
    I'll have to add you to my payroll soon it looks, answering before I even have a chance!
  5. Herr_Poopschitz
    Herr_Poopschitz Nullius in verba
    Vehicle(s):
    Junk
    May 31, 2013
    Earth
    1,242
    342
    0   0   0
    Materials science is fun!:thumbsup:
  6. Herr_Poopschitz
    Vehicle(s):
    Junk
    May 31, 2013
    Earth
    1,242
    342
    0   0   0
    So if you hit the goal, you gonna keep it there for a while and entertain us w/ some street vids?
    I take it your proprietary fueling solution is up and running?
  7. Juben
    Juben Well-Known Member
    First Name:
    Justin
    Vehicle(s):
    2015 EcoBoost Mustang (AT) w/PP
    Jan 29, 2015
    Chattanooga, TN
    2,519
    795
    0   0   0
    I've already asked him for dyno videos of the pulls lol.
  8. Brandon15ECO
    Brandon15ECO Member
    Vehicle(s):
    2015 Ecoboost Premium Black
    May 21, 2015
    Sharpsville, PA
    Correct me if I am wrong, but repeated approaches to the elastic limit will introduce a phenomenon called "work hardening", where as the material increases in brittleness over time and the elastic modulus gradually decreases. This would slightly increase the odds of breaching the yield strength and causing catastrophic failure.
  9. cosmo
    Vehicle(s):
    2005 Mustang GT
    Sep 22, 2014
    Michigan
    1,770
    764
    0   0   0
    Yep, you're right. It's also called cold working, as long as it is performed correctly. You're effectively trading elasticity for strength, and the material becomes more brittle. The graph on the left shows the effects cold working has.
    [​IMG]
  10. OP
    MAPerformance
    Gold Sponsor
    First Name:
    Sales
    Vehicle(s):
    Jan 14, 2015
    Cottage Grove, MN
    1,680
    997
    Rating:
    100%
    1   0   0
    My GoPro won't be back from warranty replacement until Wednesday. I took a phone video today on the dyno going 1st-4th but I have too much to focus on when ripping it on the street. In due time, in due time.
    The fuel system is still completely stock, 500whp was me just dicking around. The car did make some good power today but we finally found the limit of the factory fuel system on E30. I think we are going to make a switch to some "other" fuel ;) and see what it will do.
    I have already started the process of manufacturing the first prototype fuel system upgrade for testing. Hope to have it up and running in 1-2 weeks and breach the 500whp mark for real this time.
  11. bam88
    bam88 Well-Known Member
    Vehicle(s):
    2017 Ecoboost PP
    Jun 18, 2015
    Alberta, Canada
    104
    36
    0   0   0
    I must say from all I have seen so far you guys are doing some outstanding work! Once I get my EBM there will be many MAP parts inside. I am really looking forward to the coolant tank/catch can which is genius! Living in Canada presents a large struggle on keeping catch cans and their lines from freezing as happened on my last vehicle and caused a fair amount of damage. Glad to see you guys are the only ones who admit there is a problem when you see a week straight of -22 degrees Fahrenheit. Can't wait to see what else you come up with!
  12. OP
    MAPerformance
    Gold Sponsor
    First Name:
    Sales
    Vehicle(s):
    Jan 14, 2015
    Cottage Grove, MN
    1,680
    997
    Rating:
    100%
    1   0   0
    Thank you! The catch can is being pushed off for the moment, we need to finalize our fuel system upgrades and get caught up on turbo kit orders!
    Soon though, soon!
  13. bam88
    Vehicle(s):
    2017 Ecoboost PP
    Jun 18, 2015
    Alberta, Canada
    104
    36
    0   0   0
    Well if I can suggest something, when designing the catch can you please put a nice check valve in the line coming from the PCV so that the stock one can be gutted or even removed with a different PCV baffle plate. This should help increase vacuum in the crank case.
    NewSVO likes this.
  14. OP
    MAPerformance
    Gold Sponsor
    First Name:
    Sales
    Vehicle(s):
    Jan 14, 2015
    Cottage Grove, MN
    1,680
    997
    Rating:
    100%
    1   0   0
    You'll have to see what we come up with ;)
    bam88 likes this.
  15. OP
    MAPerformance
    Gold Sponsor
    First Name:
    Sales
    Vehicle(s):
    Jan 14, 2015
    Cottage Grove, MN
    1,680
    997
    Rating:
    100%
    1   0   0
    Update:
    Car is down to finalize jigging for fuel system, then we start testing. Here is a quick snapshot of what we are working on!
    [​IMG]
    We will be testing this on the factory motor and the same power level (500whp) but looking to swing in fuel heavy to make sure it works properly. We will make the switch to E85 to see if there is going to be enough fuel with the injectors that we are utilizing in the kit.
    Once we get it 100% ironed out we will be swapping the engine out of the car for our built sleeved engine with our ported head. We are looking to make some serious power in the near future!
    AngelOreo, Juben and mtpavelka like this.
Loading...
Share This Page
