MAPerformance: Ultimate R&D Thread | Air, Fuel, & Turbo Upgrades
Discussion in 'I4 2.3L EcoBoost Engine / Mods: Bolt-ons, Exhaust,' started by MAPerformance, Feb 18, 2015.
  1. RubyRedBoost
    RubyRedBoost Traded EB old name New GT
    First Name:
    Josh
    Vehicle(s):
    2015 Guard GT with PP
    Dec 10, 2014
    Fort Worth
    619
    178
    0   0   0
    I know I am
  2. greg hazlett
    greg hazlett Well-Known Member
    Vehicle(s):
    2017 Fusion Sport
    Jan 15, 2015
    Chesapeake, VA
    1,123
    169
    Rating:
    100%
    1   0   0
    Asked a knowledgeable turbo friend about the differences and here is what he said:
    BB will spool a tad faster
    BB is more reliable as it can support higher shaft rpm, generates less heat and requires less oil to lube.
    Journal bearing is a metal on metal sleeve that "floats" on a pressurized oil film that has more heat and supports less rpm as it starts to deform, needing more oil to lube and cool.
    In his opinion BB has a longer service life.
    It will probable come down to what the cost difference between BB/journal.
  3. OP
    MAPerformance
    MAPerformance Well-Known Member
    Gold Sponsor
    First Name:
    Sales
    Vehicle(s):
    2015 Ecoboost Base w/ Performance Package
    Jan 14, 2015
    Cottage Grove, MN
    1,680
    997
    Rating:
    100%
    1   0   0
    I prefer BB myself, but for the price difference (usually around $500.00) the benefit's don't outweigh the cost. For me however the cost doesn't outweigh piece of mind when you think "I bought the better turbo". I usually just buy BB for that reason.
    JB works just fine, and will produce the same power. It also can be serviced by many dealers in the USA unlike BB that has to be sent back to PTE for rebuild/service work.
    I have actually had less JB turbo's go bad on me than BB odd enough. :crazy:
    [email protected] likes this.
  4. Sup3rPat
    Sup3rPat Well-Known Member
    First Name:
    Patrick
    Vehicle(s):
    2015 Mustang Ecoboost PP Gaurd
    Feb 25, 2015
    Atlanta
    222
    60
    Rating:
    100%
    1   0   0
    Hope the intercooler is still on track to ship this week... It's really warming up here!
  5. OP
    MAPerformance
    Gold Sponsor
    First Name:
    Sales
    Vehicle(s):
    Jan 14, 2015
    Cottage Grove, MN
    1,680
    997
    Rating:
    100%
    1   0   0
    That it is, all cores are prepped and the final operation of machining on the end tanks is being finished today!
  6. FreddyG
    FreddyG Well-Known Member
    Vehicle(s):
    4 wheels and a seat
    Jul 1, 2014
    Planet Earth
    437
    42
    0   0   0
    I agree with most of what you said, but you'll see most, if not all OEM's using journal bearing turbos on their cars. I understand that most of it is a cost thing, in that the extra cost of adding ball bearings to a shaft would cut into their profit margin, but they still use the JB shafted turbos.
    How many over the road diesels are out there with hundreds of thousands of miles on them that are on JB turbos? I believe that if you're good on your maintenance, and let the turbo wind down after spirited driving (a cool down timer helps too) then a JB turbo is fine. A good synthetic oil that doesn't break down as easily and also handles heat better doesn't hurt either.
    If you want state of the art turbo design, a bit quicker spool or you have a bigger budget, then get a ball bearing shaft. Neither one is a bad choice.
    Just my .02 and you get what you pay for! :cheers:
  7. mbreinin
    mbreinin Well-Known Member
    First Name:
    mike
    Vehicle(s):
    2015 EcoBoost Premium.
    Nov 18, 2014
    New Orleans, Booziana.
    763
    214
    0   0   0
    Using water to cool a turbo is designed to prevent bearing coke.
  8. Sup3rPat
    First Name:
    Patrick
    Vehicle(s):
    Feb 25, 2015
    Atlanta
    222
    60
    Rating:
    100%
    1   0   0
    I need my fix *scratches neck* Any update on shipping of the intercoolers or turbo kit? I know, I got it bad... bit by the mod bug
  9. greg hazlett
    Vehicle(s):
    2017 Fusion Sport
    Jan 15, 2015
    Chesapeake, VA
    1,123
    169
    Rating:
    100%
    1   0   0
    Not following this one....?
  10. OP
    MAPerformance
    Gold Sponsor
    First Name:
    Sales
    Vehicle(s):
    Jan 14, 2015
    Cottage Grove, MN
    1,680
    997
    Rating:
    100%
    1   0   0
    There are watercooled turbo's on the market (PTE is not). The watercooled factor is to promoted thrust collar and bushing/bearing health. Unfortunately some cars coolant and oil temperature are the same and it doesn't help that much, or any at all. When the turbo is pushed it generate heats that will have its way with water or oil regardless. I like running water cooled turbo's on Subaru's and Honda's because their coolant system is pretty efficient and it definitely aides in bearing health.
  11. FreddyG
    Vehicle(s):
    4 wheels and a seat
    Jul 1, 2014
    Planet Earth
    437
    42
    0   0   0
    Providing that your center housing allows you to do so. Not all turbos do (Garrett's have that option, but some other's don't as MAP has stated).
    You can also prevent coking by staying out of boost a couple of minutes before shutting the car off. This lets the turbo/oil cool down, or you can put on a turbo timer. It accomplishes the same thing. :cheers:
    Sorry to go off topic MAP......Now back to our Regularly scheduled programming!
  12. OP
    MAPerformance
    Gold Sponsor
    First Name:
    Sales
    Vehicle(s):
    Jan 14, 2015
    Cottage Grove, MN
    1,680
    997
    Rating:
    100%
    1   0   0
    #432 MAPerformance, Apr 23, 2015
    Alright guys, I'm doing the final set of tuning today. Going for the HP record on stock block. As far as I know the highest horsepower is 420whp right now on a pretty big turbo. So far we are at 408/400, graph below. I have already sold 2 of these kits, so if you are interested pre-order fast. ETA right now is 2-4 weeks, with the influx of orders I will make sure to give you a good ETA at the time of placing your order.
    Pre-order is open now, please email me at [email protected] to purchase!
    Price is $3,449.99 shipped and will include the following.
    MAP Manifold (Turbo Kit Specific)
    MAP Downpipe (Turbo Kit Specific)
    MAP 3.5" Intake (Turbo Kit Specific)
    MAP Passenger side hot pipe (Turbo Kit Specific)
    MAP Oil Feed and Drain Line
    MAP Coolant Bypass Line
    Turbosmart Vee Port BOV
    Turbosmart CompGate-40mm Wastegate
    Precision 5858 Journal Bearing Turbo with SP Cover
    PTP Turbo Blanket
    DEI Heat Wrap
    Tune file for Cobb Accessport
    +500.00 for Ball Bearing Turbo
    +500.00 if you don't have an Accessport
    The tune file that comes with the kit will be for 93oct and is rated for 390hp/380tq @ 24psi. Once you get the turbo kit installed you will be required to send me multiple datalogs to fine tune the kit for your vehicle as not all cars are the same. Anyone without 93oct in their area will be covered, will product about 375hp/370tq depending on fuel quality.
    We are finishing up the welding on the intercoolers today and tomorrow, and should start shipping all the kits out Monday/Tuesday. Once we are done with those, we will be building turbo kits. Once I have a brand new turbo kit ready I will post up pictures and get a product listing on our website!
    [​IMG]
    [​IMG]
    The dynograph below isn't final, it just gives you an idea of the powerband that the car is producing with our kit. Remember, the kit you receive will come out of the box setup to run 390hp/380tq which is good middle ground to have good power with reliability.
    [​IMG]
    re-rx7, jvbeattie, relykz and 5 others like this.
  13. Surtur
    Surtur Well-Known Member
    Vehicle(s):
    Apr 2, 2015
    Tallahassee Florida
    573
    213
    0   0   0
    great now i have to change my pants...thanks a lot.
    AngelOreo and MAPerformance like this.
  14. boosted_orange
    boosted_orange Well-Known Member
    First Name:
    Alex
    Vehicle(s):
    2015 Ecoboost PP
    Jan 7, 2015
    San Antonio, TX
    399
    46
    0   0   0
    I feel ya on that one...Lol
    MAPerformance likes this.
  15. bluestang50
    bluestang50 Well-Known Member
    Vehicle(s):
    2016 DIB GT PP, 2017 F150, On order: 2021 Mach E GT
    Oct 31, 2014
    GA
    285
    129
    0   0   0
    Awesome work Adam!
Loading...
Share This Page
