Mach01
Getting a suspension rattle over bumps, esp. while turning at <20 mph intermittently passenger side.
When first heard it was strut to spindle bolts not torqued. Torqued them down with blue locktite and ordered fresh set. Sound gone for 300+ miles. This time they were still fine (new ones not here yet). Also checked sway bar end links (BMR Adj)
Checked the top out on ground and the strut top nut is very tight but spins. Don't think it's this one, but I'm gonna put a gun to it.
Three little strut mount nuts (maximum Motorsports caster camber plates) were good. Wheel lugs good.
It's a fairly significant rattle.
However a short Test drive didn't reproduce noise. Could be something else not secured during alignment? What do they mess with on the front end alignments? I can tell you the dealer did not tighten to spec the strut to spindle bolts following alignment, twice. Rolled out of the dealer with the noise.
Any ideas? Tempted to put the OEM sway bar end link back on.
Current Suspects: strut to spindle bolts, engine mount, sway end links, stupid hood brace(OEM).
Mods: Ford racing struts, Steedas springs, sways, mounts, K and tower brace, BMR Sway end link, max Motorsports caster camber plates
