Making Speedo/Tach Cluster Show Boost with GT V8
Crumpler
Minneapolis
2016 GT PP DIB SC
I own mulitple boosted GT's. 2 have roush 670 kits. One shows boost on the main cluster center screen the other shows just vacuum. Anyone know how or why boost shows on my 15, but not the 16?
(yes it shows boost under boost)
WestCyril
Southwest
boos/vacuum gauge was only on 15. No other model has it. Just like 16s only have turn signals in the vents. Just things ford randomly includes and removes with different years.
moffetts
San Mateo CA
Black Whippled 2015 GT PP
I have a 15 GT PP and I've never seen either of those readouts.
tsloms
Wisconsin
2016 Mustang GT Magnetic PP
With the Performance Package they removed it from the dash and added that vacuum gauge to the center of the dash. It can't be viewed between the gauges.
Crumpler
Crumpler
Minneapolis
2016 GT PP DIB SC
Maybe it's a 2015 thing? For record I purchased a brand new pp 2016 gt and installed a roush/ford 670 supercharger. The 2016 pp did for sure have the vacuum gauge in the speedo cluster as well as the mechanical looking gauge above the radio. After downloading the roush tune, the digital gauge still read vacuum only. (of coarse the mechanical looking gauge could not show boost). Side note: if you buy the gauge pair for an eco-boost that has vacuum and boost, it is a direct plug in and will show boost (at least on a 2016). I know this because it did it. I have had 4 supercharged gen 6 cars. one PP. all have the vacuum gauge in the speedo cluster. The picture showing boost that I put in the first post is a car I own that is a roush superchared v8 gt 2015 showing boost.
MyLilPony
Naw It's Stock
Prosper, TX
Kris
2015 Black GT, 18 JLUR, 15 JK
I have a 15 and i have it, but i never use it...most inaccurate gauge I have seen. Same goes for the PP ecoboost gauge, I have heard (no experience) that it is just as bad...
moffetts
San Mateo CA
Lame. The analog vacuum gauge is completely useless.
Phoenix
Instagram: PhoenixNFA
Central Texas
2016 GT350 Tech AvGrey/Black Stripes
i have a 15 auto and i use it just to know when the car is in boost or not (mpg and stuff). mine reads 9-10psi but im pullied for 12.
Crumpler
Crumpler
Minneapolis
2016 GT PP DIB SC
Yea, same here just using it as a guide. And for the PP analog looking gauge, I installed it just for looks. Sounds like maybe 2015 only show the boost.
Jaehead
Columbus, IN
2016 GT/CS
boost gauge doesn't work, even the ecoboost ones. it's just a calculated value, if it was a real reading it'd show up on the dataloggers..
Crumpler
Crumpler
Minneapolis
2016 GT PP DIB SC
They are definitely not accurate. But, I wonder if they are precise. (same readings giving same circumstance every time)
Marvinmadman
Louisiana
16 EBM
My gauge is pretty accurate. My boost shows up in my logs. I'm not surprised as the ecoboost has MAP sensors. :shrug:
venumous
PA
16' Procharged GT
They use load algorithm to calculate boost as I understand it. Not going to match up with actual boost a majority of the time. Even those of us with all Lund tunes and similar boost have drastically different load values.
