There’s a reason Ford has holes blocked off on the GTs and GT350sCan't tell, but are a lot of those holes on the bottom grill still plugged up? Or are they open? Only thing I would've done maybe (lotta work though) is open up the entire honeycomb. Probably changing out my lower grill at some point. Upper isn't too bad but I need to open up all the holes.
Care to explain why? I've always wondered this.There’s a reason Ford has holes blocked off on the GTs and GT350s
Drag doesn't just hurt mileage, it hurts acceleration and top speed too.It is to reduce drag to squeeze more MPGs. The very open RTR grills I had on my 15 reduced IATs significantly. Here in Texas that is more important to me than a very slight improvement in drag coefficient.
Most of them are covered, as I saw it a pain to open them up or changing the mesh out.Can't tell, but are a lot of those holes on the bottom grill still plugged up? Or are they open? Only thing I would've done maybe (lotta work though) is open up the entire honeycomb. Probably changing out my lower grill at some point. Upper isn't too bad but I need to open up all the holes.
I made a thread about it if you want to read why. At the end, I resorted to paypal to get a refund.Looks good! The Cervinis upper and lower combo is on my list. What issue did you have with them?
Instead of cutting the back out of each individual "cell", you can just grind thru the backside for all the cells in an area. Those cells will be a little shallower that way, but its black and in shadows so nobody will notice.Most of them are covered, as I saw it a pain to open them up or changing the mesh out.
It does, but I don't think it will make a big difference in speeds most people will hit. The 200 mph GT500 came with a grill delete because heat was a bigger enemy than drag (I know the blower makes it a bigger issue). In some places it may not be as big of a factor but in the hot South temps really climb and timing starts to get pulled making less power.Drag doesn't just hurt mileage, it hurts acceleration and top speed too.
