Mach 1 parts from other models
Tinpot
UK
2022 Mach 1 w 3rd pedal delete
I look upon it as an improved PP2 (diff. cooler & transmission cooler, stiffer subframe bushings and toe links) that now has the option of street tyres - base Mach 1 - or track tyres - Handling Pack. Overall, a nice evolutionary update from the base GT > PP1 GT > PP2 GT > Mach 1
young at heart
Deep South
20 GT vert A10 / 23 Mach 1 A10 / 23 Mach 1 Tremec
What exactly is a spat? Is that an American thing and I just didn’t know it or have we borrowed it from Europe?
autobahnGT350
Northern Virginia
2016 GT 350
Is the Mach 1 transmission with oil cooler the exact same one as in the GT350? Does it mount the same and has the same transmission cooler components? If so, this means one can order a Mach 1 transmission for a Gt350 with a non cooled transmission and retrofit it.
BlkMach10510
BlkMach10510
2023 Mach 1
From a Forbes article: "From the Shelby GT350, the Mach 1 takes its standard Tremec 6-speed manual transmission. "The engine also gets the same intake manifold, oil filter adapter, and engine oil cooler as the GT350."
murick
Prague, Czech Rep.
Richard
2021 Euro Mach 1
I believe someone posted here that while in general it is the same Tremec as in GT350, there are some differences in clutch, and elsewhere. Also Mach 1 has no-lift-shift and auto rev. matching.
BlkMach10510
BlkMach10510
2023 Mach 1
Updated list for the Mach 1 DNA
BULLITT
Engine – Modified Bullitt Engine
MUSTANG GT PERFORMANCE PACK 2
Spoiler
Brembo Six-Piston Front Brakes
Engine Spun Aluminum Instrument Panel
Gauge Pack (Oil Pressure and Vacuum)
Heavy-Duty Front Springs
K-Brace
Larger Radiator
Performance Rear Wing
Black Painted Strut-Tower Brace
TORSEN Differential with 3.73 Axle Ratio (Manual)
TORSEN Differential with 3.55 Axle Ratio (Automatic)
Unique Chassis Tuning
Unique Stability Control, EPAS, and ABS Tuning
Upsized Rear Sway Bar
Front Splitter
SHELBY GT350/GT350R
Air Intake
Intake Manifold
Engine Oil Cooler
Oil-Filter Adapter
Tow Link
Tremec Six-Speed Manual Transmission
Throttle Body
Transmission Cooler
Michelin Pilot Sport Cup 2 Tires (Mach 1 Handling Package) (GT350R)
Lower Front Vents
Stiffer Bushings in Front and Rear Subframe
Tire Fitment (Mach 1 Handling Package)
Incandescent Park/Turn Lamps
Adjustable Camber Plates
Differential Cooling System (GT350R)
SHELBY GT500
Rear Axle Cooling System
Rear Diffuser
Exhaust Tips
Mufflers
Rear Tire Spats
Swing Wing with Gurney Flap (Mach 1 Handling Package)
Rear Toe Link
Splined Intermediate Steering Shaft
ajsfirehawk
Colorado
Alan
2023 EG M6 Mach 1 ordered. 12/1; Received 2/3
What is the difference between these two? I know there is a Diff cooler on the Mach 1. What is an 'axle cooling system'?
SHELBY GT500
BlkMach10510
BlkMach10510
2023 Mach 1
SHELBY GT500
idk, I just gathered my list from different articles. Even on this thread the cooling is listed for both. It lists it for the GT350/500. I must have found it again for the cooling seperate into the two shelby's from an article/s. I started this thread from my own curioisty and guessed others would like to know too and found out some articles conflicted with each other so sometimes there is guessing involved by the part, lol.
