luc
You have a retaining washer on the other sideI wanted to mount the oil catch can today and got stuck on something I am not sure is right.
I was trying to loose the cam cover bolt to replace it with the stud bolt.
only to find out that I was not able to pull it out. The bolt felt completely loose from the nut, I could wiggle it freely, but at the same time when pulling it out it always got stuck on something, like if there was another nut or bushing on the bolt from the inside which did not fit the hole.
This is as far as was able to get it.
Trying to "unscrew" it further had no visible impact. It felt as stuck as before and as loose as before. I only applied a mild force trying to force it, being afraid that if there is indeed anything on the bolt and I manage to loose it, it might as well get lost inside the chamber.
Despite that I could easily screw the bolt back into its counterpart and tighten it up.
I am not sure what to do. Anyone faced a similar problem?
