We are happy to bring you another Mustang6G and J&M Products / @Hotpart.com Giveaway Contest!
PRIZE
- J&M Products / Hotpart.com New Bump Steer Kit
- See full product details on the Hotpart website.
- See the product thread on the forum.
PRODUCT DETAILS:
- Corrects Bump steer, prevents twitchy unpredictable steering
- A necessary addition for lowered cars
- Tapered stud is correct size, no need to drill out the spindle or use a bushing for proper fit
- Easily adjustable, adjustment hex in the middle
- Works in conjunction with other suspension modification
- Mil-A-8625 Type II Black Anodized finish for corrosion resistance
- Fits 2015-Present Mustangs with Power Racks (does not work on manual racks)
- Replaces factory tie rod ends with spherical rod ends for precise steering control
- Aerospace T6061-T6511 aluminum
- Rod end bodies are constructed of heat treated chrome-moly alloy steel and clear zinc plating
- Tapered stud is machined from solid 4130 chrome-moly, and heat treated to the tensile strength of a grade 8 bolt
- The ball in the rod end is 52100 steel and hard chrome plated
- Threads are rolled not cut after the heat treat process for maximum strength
- Rod end liner is sintered bronze with PTFE impregnated for the strongest liner on the market. (not the standard PTFE liner)
CONTEST RULES
Who
- This giveaway is only for members who will be installing this product for personal use on their S550 Mustang (not for resale).
- The giveaway contest starts now and will end on Friday night, August 16, 2019 at 11:59pm ET.
- The winner will be chosen right after the contest closes and announced the following day.
- Post a photo of your S550 Mustang to enter.
- Your post # will become your virtual raffle ticket.
- Only one entry per user. Multiple entries from the same person (or registering multiple user accounts) will result in the deletion of all your entries and suspension of your account.
- At the close of the contest we will randomly select (using a random generator) one number from the total number of posts in this thread (minus the OP). The member who made that post will be the winner!
Thanks again to our generous friends at Hotpart.com!
**NOTE: This is not an open thread for discussions. Any posts that are not an entry for this giveaway will be deleted.**
