I haven't seen any dyno numbers from livernois, have the posted them or just the quarter mile time?I think livernois actually got higher numbers then Lund
They posted them. I won't put in here, but will find in the thread I saw and post in their threadI haven't seen any dyno numbers from livernois, have the posted them or just the quarter mile time?
So you are talking shit without knowing what you are talking about? Color me not surprised...Color me impressed. I had not seen that dyno run showing over 400 lb-ft torque. I'm still not convinced this is a sustainable tune. I did not mean that it was not possible, just that it would not work long term as a DD tune. I might be wrong but I guess only time will tell on that front.
Once again...you have no evidence or basis for believing this.I'm still not convinced this is a sustainable tune.
Amen.These things are going to be damn impressive with a turbo upgrade.. I'd like to build one with a 6266 in T3/T04E housings. Small (.48) A/R turbine housing should get it going pretty early.
Travis is it safe to max out the turbo like that? Would there be problems in the long run if you do that?The only reason that the TQ figure is so high, is because they're maxing out the turbo. You get the big TQ surge at low RPM, but as the RPM rises, and engine airflow exceeds what the compressor can supply, the boost drops, and so does output. It's not a bad thing.. it just depends on what you're doing with the car. For a daily driver/around town/drag racing, this thing would be a blast to drive. I wouldn't go road racing with it.. but, that's just a turbo upgrade away.
If you upgrade the turbo, then would you have to upgrade the intercooler too?The only reason that the TQ figure is so high, is because they're maxing out the turbo. You get the big TQ surge at low RPM, but as the RPM rises, and engine airflow exceeds what the compressor can supply, the boost drops, and so does output. It's not a bad thing.. it just depends on what you're doing with the car. For a daily driver/around town/drag racing, this thing would be a blast to drive. I wouldn't go road racing with it.. but, that's just a turbo upgrade away.
