Lowering & Rear pinion seal
ghst
North Bay, CA
2015 GT Premium PP 401a RIP
Just curious if anybody has had issues with the rear pinion seal starting to leak or anything after lowering your car.
My previous mustang had developed a leak from wear on the pinion seal after lowering it. Not sure if that's an issue with the S550's or not.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
The beauty of IRS. Not an issue as lowering doesn't change the driveline angle. It does change the halfshaft angle, though.
ghst
North Bay, CA
That's good to hear, actually. Thanks! I'm assuming the halfshaft angle being off won't have any long term negative effects?
jasonstang
Omaha, NE
2017 GB GT/CS 6MT
Slightly off is okay as long as they are not at an extreme angle.
BmacIL
Enginerd
Naperville, IL
As long as you're not lowering over 1", I would not expect them to fail earlier, unless you're at significantly elevated power levels. Stick to 0.5" or less of lowering and you're good for sure.
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
[MENTION=28465]ghst[/MENTION]
Did your pinion seal start leaking?
