ShatterPoints
- Apr 22, 2020
- Austin Texas
- James
- 2017 GT350
The shocks on your car have a range of force they are capable of generating. Lets just say that number range is 1-10 and your OEM springs require ranges 2-8, that is within the designed performance profile. Now take your FP aftermarket springs, lets say they require the shock to perform in ranges 4-9, that still works and you can say that those springs will work with the OEM shock. It's not that the spring itself is designed for the shock, rather the shock has the ability to dampen a range of spring rates, and like anything you can miss match them and get to a result that is outside the range the shock is capable of performing in.do you mean as in getting aftermarket shocks? When I spoke to the Ford performance tax he said the springs were designed for my stock shocks and that I wouldn’t have to reset them or re-calibrate them everything would work appropriately.
A rule of thumb is you can move +/- 30% from the OEM spring rate and still have relatively ok performance, this is less true the further away from sports car you go (for example a prius).
