ShatterPoints
- Apr 22, 2020
- Austin Texas
- James
- 2017 GT350
Close...from everything you stated I gathered the following information in short:
1. the 565 lb/in for performance springs were engineered that way to return to equilibrium slower (on time I guess) to prevent bounce on the road courses to keep the rear end more stable, for better traction. Which will mean less bounce on the street at lower speeds and sharp bumps. Allowing them to get progressively stiffer at faster bumpe. Effectively removing sloppiness or bounce. Pretty much trying to eliminate anything that would not allow full control or traction of the rear.
2. ford should have use these springs in the cars oem setup but didn’t do so to make extra money and they sit to low due to warranty claims.
1. Springs oscillate at a given frequency which depends on the weight of the vehicle and the rate of the spring. A softer spring oscillates faster, and since the spring's job is to reset the suspension to static ride height all it does is allow the suspension to move as it compresses and extends. The SHOCK is what controls the amount of time the sprung system returns to equilibrium. The shock RESISTS compression and rebound and so the more of each you have the slower the shock is. The best way to think of it is, springs control HOW MUCH weight is transferred and shocks control HOW FAST that weight is transferred.
2. The OEM springs are setup so that the front end has a lot of mechanical grip in relation to the rear (the more front grip the less understeer) the OEM shocks are designed to match that design. The FP springs will solve the bounce you are feeling but in an incomplete way and will cause the car to pitch much more than it does now. You will encounter low speed understeer with the FP springs on the car. At higher speeds it will be fine, typically you want a car that oversteers in low speed and understeers slightly or is neutral balanced at high speeds. Though there are plenty of people happy with whatever works for them.
