Low oil pressure warning 300 miles after oil change
JUH
Central PA
Jakob
2015 Mustang Ecoboost 50th Anniversary Edition
I changed my oil about 300 miles ago, and now I'm getting a nonstop "Low Oil Pressure" Warning.
Have any other EB owners experienced this? I checked my dipstick and it was fine, and I don't think I have any leaks. My car has been jumping RPMs weirdly every now and then (like when I slow down it'll jump from 3k to 2k).
I thought it was a computer issue, but now I'm thinking it could also be my oil filter. I'm not sure.
Rapid Red
Woodstock GA
Greg
Not running a Fram filter are you?
JUH
JUH
Central PA
Jakob
It was a new brand that I don't usually get, but I don't think it was a FRAM.
I can check once I'm at my buddies garage since I can't really check for the exact brand at the moment.
revinto7
NY
07 shelby-gt 14 camaro SS 1LE
only use motorcraft filters ,you have a colapsed filter and are starving the car for oil ...
dgc333
MA
15 Mustang Ecoboost Premium
Oil filters are designed to bypass when the pressure drop across the filter media goes above 12 psi such as the media collapsing. As a matter of fact the filter bypasses on every cold startup to ensure the engine is not starved for oil. Doubt the cause of the low oil pressure reading is a collapsed filter.
Motorcraft filters are a good choice but they are nothing special. They are just a rebranded Purolator filter.
FWIW, In the last year I have had two Motorcraft oil filters that leaked.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Youre right, I completely forgot about that. I think its a false alarm personally, or OP is about to have an ejected rod.
JUH
JUH
Central PA
Jakob
What did you use for your oil? Should I get another oil change (maybe not do it myself this time)?
Do I need a new part? The Ford Dealership isn't taking people t'ill the Oct. 15th, and I need the car pretty badly.
Rapid Red
Woodstock GA
Greg
I don't know WIX seems to be an excellent choice .
Andrew@Lethal
West Palm Beach Florida
Andrew
I would change whatever filter you used to a OEM motorcraft ASAP in case it might harm something. Spending another $30-$40 for peace of mind is a lot cheaper than a new motor. Do not drive the car in the meantime until you change the filters out.
