- Dec 20, 2014
- Lake Worth, FL
- Website
- www.uprproducts.com
- 15 GT
With power so easy to make on these motors, you now have other factors that will come into play. One key item is the Driveshaft Safety loop. This little brace is actual required by NHRA and IHRA tracks when your running 13.99 or faster. Also, with any aftermarket shaft, these are a must!
So we are proud to now offer the BOLT-IN loop from UPR! Like previous years, this bolts to the factory transmission mount and can be installed in no more then 15minutes.
These loops are made with a 2" wide loop that are 1/4" steel and locates within 6" of factory u joint making it NHRA legal.
Couple Key features:
» USA Made
» Zinc Plated Finish
» Bolt-in Installation
» Easy 15 minute install
» Fits 11-15 Mustang GTs
» Grade 8 Hardware Included
» 3 Piece Front Drive Shaft Loop
Now.. with installing this loop, you can do it on jackstands but I would at least raise the front end as high as possible so you can slide under the car with some room. When we installed it, it was on a 2 post lift (which we always recommend)
The tools used are simple sockets and wrenches. You do not need to drop the entire transmisson mount for this eaither so their is no bracing anything.
******* LET THE CAR COOL OFF BEFORE THIS INSTALL AS YOUR HANDS WILL BE AROUND THE EXHAUST*******
As you can see in this picture, this is how it looks on your car factory
Once the car is raised securely, go ahead and remove the back 2 transmission mount bolts (the 2 closer to the bend in the exhaust)
From here, your going to mount the bottom brace to the factory transmission mount.
After that, you are going to take the loop bracket and attach it with the supplied hardware to the bottom brace. (when you install it, you will have the 4 holes at the top where the loop would go.
Once the loop mount is on (do not tighten yet) You can go ahead and slide the loop around the driveshaft and use the bolts to secure it.
Once you have everything on in place, you can go ahead and tighten the bolts down (no torque specs needed)
NOTE ------ This will work with any aftermarket shifter
And that is it!!!
Items used: UPR Driveshaft Safety Loop
Installed Location: UPR
Time to install: 15-30minutes (with correct tools and lift)
You can order yours over the phone at 561-588-6630 or online at
http://www.uprproducts.com/mustang-heavy-duty-driveshaft-loop-11.html
» USA Made
And that is it!!!
