Looking to get 19 or 20 inch wheels. Cons and pros
ethanhunter34
Hawaii
2020 Ford Mustang gt California special
Hi
I was looking at the 6GR 5 spoke wheels in 19 or 20. Any difference or just more of a personal choice.
FreePenguin
Ohio
Donald
17 mustang
If roads are crappy, 19 is safer for
roomk101
California
2019 Mustang GT PP1 Whipple Stage2
Just made this choice myself (P6GR ten spokes). Ended up landing on 20" due to the lack of tire options for 19".
Specifically, I wanted Michelin PS4S tires with a 35 sidewall. Only options for 19s were 295/35/19 (too skinny on the 11" wheel IMO), and 305/30/19 (305 would have been fine, but again, wanted the taller sidewall).
Setup I went with was 20x10/11. 275/35/20 Front, 315/35/20 Rear. Zero regrets, looks and drives amazing. Pic below, 1" lower front and back.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Looks amazing! Great setup.
armykyle1 [HACKED ACCOUNT
Gulf Coast
2018 GTPP premium
I started off with aftermarket 19s with a 305 30 MPS4s and was not happy with the lack of sidewall and overall appearance.
I'm now running 20s with 275 35 20 front and 305 35 20 rear. Car looks perfect and rides great. There's plenty of sidewall.
Last picture is 19s for reference with a 1" spacer up front.
I'm lowered 1" on all four corners with steeda mag ride lowering springs.
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
If you're running 35 series there is no difference. The sidewall height is the same.
That's true, but some are interested in keeping the overall tire diameter closer to stock so it doesn't impact the speedo so much and make the car accelerate slower. A 315/35r20 tire is more than 1 inch taller than most stock setups. But it does look good the way it fills the wheel gap, and it allows you to run at stock ride height or slightly higher with lowering springs installed. :)
Matti777
Edmonton
Matthew
2020 Mustang GT
Can't have everything. Stick with a 19 inch wheel.
ethanhunter34
Hawaii
285/35/ 19 and 325/3019. The rear has a smaller sidewall in the rear if you go wide.
roomk101
California
Lucky for me, the tune programming tool that came with my Whipple kit allowed me to program in the different tire size. I would assume there would be similar programmers you could buy (or borrow from a shop) to do the same.
MidwayJ
Dallas, Texas
Jay
I would expect any aftermarket tuner can make the adjustment. Pretty sure it's doable with forscan, too.
Gulf Coast
2018 GTPP premium
305 35 20 fits fine on the back with 1" lowering springs. I just ordered 315 35 20 nt555r2 and I may have to adjust the rear cradle a little bit. It's not perfectly centered, even with the Steeda alignment kit. This is a common issue on S550s. My 15 had the same issue.
20s are fine.
