Looking for wisdom cliffnotes on higer HP MT82/6speed people
BlowerGuy
Wyoming
Corey
22 GT500, 2018 GT A10, 06 GTO
18 Whipple w/ MGW - 800 ish RWHP.
bought it done....I'm ignorant but learning. I'll apologize because i'm a '04-06 GTO guy. Like horrible. I have 3 of them.
1.94 60' last night on MT 18" radials. Dumping clutch at 4600RPM and we're getting a good bog. Missed 2nd once, and 3rd once. 3rd gear I swear wasn't me.
1) How long is this thing gonna last with me treating it like a Hertz Impala rental? I'm gonna get a 15" rear wheel/brake setup very soon.....I want to see some 1.4 60 foots.
2) - I'm guessing the MT82 is on borrowed time, and it looks like it's worth aluminum scrap from my searching of the site. So, with that - I've got a faceplated T-56 that would need a bellhousing etc. to make it work. It's fresh from Liberty, which I got from a buddy. Just a spare for my 600RWHP GTO....I can't imagine the clutch would use the same input - but maybe? Even if I don't use my faceplated transmission, I can't imagine the $1500 CF driveshaft would work with a different YOKE? Or would it?
3) What vendor/dealer is the best at transmissions for these Coyotes? Who's got a whole setup in stock, ready to rock. I just want a setup that is bulletproof so I can beat the shit out of this car until Sept 1st.
Throw me whatever little tidbits of information I can use the keywords from to search the site. I'm just having a hard time combing through the threads, because they are mostly stock car issues with more miles. Since I'm beating the hell out of it behind a whipple, it would be nice to find people with similar cars so I can see potential hazards and the fixes.
rebellovw
Prescott AZ
2018 Mustang GT Premium PP
Yeah it is scrap cause you are throwing 800HP at it and dumping in it constantly. These threads piss me off.
BlowerGuy
BlowerGuy
Wyoming
Corey
I'll assume I'm receiving some misplaced anger. Because if this pisses you off your 3 yr old somehow logged in and responded to my thread or you might have issues you need to get worked out. I really don't need your 5 second assessment and .0005 seconds of thought put into an answer here.
Anyways, just looking for some good information about these transmissions in higher HP use.
aleccesarenriquez
San Antonio, TX
Alec
2017 GT PP
Ben Calimer is usually the go to guy for trans related things in the mustang world.
I would also recommend you join the stick shift coyote fb page. Lots of good info there if you just search up specific questions.
Anyways right off the bat, here are some things most people will tell you from what I’ve read;
1. Get a set of bias ply for the track. Mt82 doesn’t like launching on radials.
2. I don’t know what else is done to the car but you definitely need a Twin Disc, one piece driveshaft, stronger half shafts, and a lot of suspension work. I hope most of this has already been done to the car.
3. Most people will tell you to slip the clutch. You could also consider the n2mb (2step and wot box).
4. If it feels like you’re hitting a gate during the shift and you don’t think you’re actually missing, it’s probably your clutch if you’re still on the stock one. I’m guessing it’s only at high rpm? It’s usually the clutch or shifter but you already have the mgw so only leaves the clutch.
5. Lastly, you can try to keep your mt82 but I would bet things will always be breaking on you if you track the car often. At the end of the day, the mt82 isn’t a good trans. You could spend $3k to get the stage 3 from Ben with gforce gears rated at 1000 hp but at that money, t56 or tr6060 swap is right around the corner in terms of price and those trans are far superior.
boB
boB
2019 GT PP1
Two threads below this one is a thread on how someone installed a Tremec Magnum in place of the MT-82. The GT350 has one so all the parts are available.
One measure of xmsn strength is the shaft spacing. The MT-82 is … yes, 82 mm. The Tremec is 85 mm so about 4% stronger to start with. The gear ratios also play a part and the lower (numerical) 1st gear adds strength. Tremec is probably a better way to go for what you are doing.
saleen367
MN
Jeff
2022 Mach 1 HP N3451 2015 Focus
Ben Calimer ... I think Lethal sells them as well as VMP. He also builds Tremec units and you can find him on FB .. do a search for Calimer Transmissions.
whatsup62
Jupiter
Scrap the MT82 and go with the Magnum or TR6060... I did the 6060 and have no regrets...800+rwhp and the Tremec takes it all day long.
Ghost50
Houston by way of Philadelphia
2019 Magnetic Metallic GT PP1
All of this is great info for MT-82 guys.
Kong76
Turlock, Ca
2016 Ingot Silver GT
Gt350 is a Tremec but not a T56. It's a TR 3160 with a rated 429ftlb of torque. It too has it's own issues. Magnum XL or Tr6060 like 62 said.
boB
boB
2019 GT PP1
You're right, the 3160 is only 81 mm shaft spacing but the 6060 is 85 mm like the T-56.
BlowerGuy
BlowerGuy
Wyoming
Corey
I took your info to heart. I reached out to Calimere, but I guess he doesn't do anything but phone. I'm a email guy for the most part, largely because in text it's hard to get screwed by he said she said.
Anyways, after dropping $6K with Terry on Wheels, slicks and knuckles and after last thursday night where I finally started side stepping the T56 in my GTO - I'm in the hunt for a T56.
Largely, I'm looking to find out if my CFiber driveshaft is any good with a different yoke, or If I'll have to buy a whole new one.
If possible, I'd love to have this all together in two weeks....but finding someone with all this in stock might be tough.
aleccesarenriquez
San Antonio, TX
Alec
2017 GT PP
It sounds like you’re making quick moves!
Yeah Ben pretty much only responds to calls. He usually doesn’t pick up but he calls you back 50% of the time. Just gotta keep trying him.
I’m glad Terry was able to help you out. I hope his advice aligned with what I suggested. He definitely knows the platform so I would take his word for any advice on our cars.
Good luck on the build
PS. Just to make sure there’s no confusion, whenever we mention the T56, we’re e always talking about the Magnum XL version (at least I am and I think most others are).
BlowerGuy
BlowerGuy
Wyoming
Corey
What 1st gear is everyone using? I see there are some choices.
I'm sure thinking this thing needs 3.90's like my GTO. GTO has a pretty deep 1st, but it works for me.
6th gear with this mt82 is useless. 85 mph maybe....that's with 3.73's
BlowerGuy
BlowerGuy
Wyoming
Corey
Talked with Ben - he said the 18+ MT82 has much better gears. He said it's almost as strong as the alternatives. He said most guys are breaking shift forks. So, I guess.....we'll let her buck first.
Enzo
Orlando
Enzo
2018 Mustang GT PP1
T
this Is interesting. Really good to know! I heard a lot of guys break forks on them. I actually my transmission swapped, but the fork thing wasn’t my issues. I had problems not getting into gear.
