oesman
- Feb 18, 2016
- Houston, TX
- Dmitry
- 2016 Mustang GT PP
Hey Guys,
I put together a list of tire combinations that fit GT PP wheels. This was in part due to my search for street grip for my ProCharged GT PP. I will also be buying a second set of wheels, probably 18s, for running slicks and DOT slicks, I'm still working on that list.
What this list is:
- Tires marketed by the manufacturer as their most aggressive models.
- Tires ranging from 255 to 305 width.
- Tires staying within 3% of original diameter.
- I tried to grab prices for tires when available.
- Sizes were found on manufacturer's site, may have to be ordered from dealer as some are clearly not in stock anywhere.
I have excluded:
- Tires marketed specifically as track only, despite DOT approval.
- Tires that are essentially similar but marketed as less aggressive versions of same manufacturer's models, i.e. Michelin PS2s were excluded since Michelin Super Sports are on the list.
Questions I have are:
- Have I missed any tires? - I'm open to adding things I missed, shoot me a list either in PM or in the thread.
- What do you guys like to run on the street?
- Does anyone see any performance (not cosmetic) point in going over 275-285ish on 9.5" rims? As far as I can tell anything wider is sort of like riding on a balloon, the bulging sides past the rim width don't really grip much. So far my research and members posts indicate that it is a bad idea to exceed the 9.5" rim size.
EDIT 12/12/2016:
I'm uploading a list (Build Sheet - Streetable Tyre Options.pdf) of all my currently researched streetable tires which gives more flexibility to mix and match against the initial list (Build Sheet - Street W+T.pdf) I uploaded. That initial list (Build Sheet - Street W+T.pdf) is specific to the GT PP rims while the new list I added has 18" options as well and other profiles/sizes that may not work on the GT PP wheels.
I'm going to consider creating a google doc we can all work on or just adding more to what I have based on other's suggestions. I'm going to revisit my initial list and add non-staggered setups too!
What this list is:
I have excluded:
EDIT 12/12/2016:
