robvas
Remember that the different oil specs change
WSS-M2C931-B was the old spec
Then WSS-M2C931-C, and now WSS-M2C931-D
Each spec meets the previous specification requirements
But what is in the spec?
A lot of it is stuff like how much zinc of phosphorus can the oil have (for the catalytic converters to have a long life). And the new D spec is basically changes in the additive package to reduce LSPI (low speed pre-ignition) in today's DI (direct injection) engines.
A lot of the previous euro spec oils, for example, didn't meet this. And some oils like Castrol GTX which would be recommended by companies like BMW or Porsche had too much zinc to meet the C spec!
Does that make them bad oils? No. lThe GT350 doesn't have DI so you don't have to worry about the D spec, for example.
And the owners manual doesn't even require you to use oil that meets the Ford spec, just API SN+ spec.
We recommend Motorcraft® motor oil for your vehicle. If Motorcraft® oil is not available, use motor oils of the recommended viscosity grade that meet API SN PLUS requirements and display the API Certification Mark for gasoline engines.
