nastang87xx
I'm guessing that he specifically can't run 315s up front because a 315 will fit up front with the right wheel.Why cant you run 315s on the front?
ah I see I have a spacer I can remove if necessary.I'm guessing that he specifically can't run 315s up front because a 315 will fit up front with the right wheel.
They sold out months ago then another batch of 20 or whatever showed up. I got 4 fronts earlier this year but haven’t seen them since. Didn’t realize I’d heat cycle out rears at 8 days vs 4-5 days chording fronts, so stocked up on the wrong ones a bit...I'm running a set of these right now. GOing onto my 5th day. Hmmm.....didn't realize there were more
They'll fit fine up front. Have a few buddies that have run the 315 tire up front. I run them square on 19x11 et50 wheels with 25mm spacersThey sold out months ago then another batch of 20 or whatever showed up. I got 4 fronts earlier this year but haven’t seen them since. Didn’t realize I’d heat cycle out rears at 8 days vs 4-5 days chording fronts, so stocked up on the wrong ones a bit...
The 315 doesn’t fit/work well on the front of the R with cf wheels does it? I figured it might rub and I’ve never had luck / been a fan with messing with different size tires. Screwed up the PSM badly on my 911 doing this, and also got bad rubbing on the track.
They will fit fine up front without needing spacers on the cf wheel?They'll fit fine up front. Have a few buddies that have run the 315 tire up front. I run them square on 19x11 et50 wheels with 25mm spacers
yepThey will fit fine up front without needing spacers on the cf wheel?
I guess another question, any reason I can’t put my spare rear cf wheels with 315 up front (no spacers) to try 315 square setup on all oem rear cf wheels?They will fit fine up front without needing spacers on the cf wheel?
They won't fit without about 25mm or more of spacer since the offsets are differentI guess another question, any reason I can’t put my spare rear cf wheels with 315 up front (no spacers) to try 315 square setup on all oem rear cf wheels?
There are 2 questions there: will the 315 work on a 10.5" rim width, and will the resulting package clear the strutWill the 315's work up front on a GT350 with the standard non R 10.5 inch wheel without a spacer?
I haven't personally tried this, but it isn't an ideal setup. The 315 is slightly pinched on an 11in wheel, so it will be much more pinched on a 10.5.Will the 315's work up front on a GT350 with the standard non R 10.5 inch wheel without a spacer?
