TX-Ripper
Let’s talk about 10r80 Starting Line Ratios (SLR):
The coyote engine has a 92.7mm stroke or roughly 3.65”
cartechbooks.com says we should be around 10.5 to 11 starting line ratio (3500lb-4500lbs)
Per Wikipedia the Ford 10r80 has roughly a 4.70 1st gear ratio and 2.99 2nd gear ratio
Using 2nd gear leave (2.99 gear ratio) gets you a much better SLR
Quick math
3.55 rear axle gear
3.55 x 4.70 = SLR 16.685
3.55 x 2.99 = SLR 10.614
3.31 rear axle gear
1st gear leave with 3.31 x 4.70 = SLR 15.557
2nd gear lave with 3.31 x 2.99 = SLR 9.896
3.15 rear axle gear
1st gear leave with 3.15 x 4.70 = SLR 14.805
2nd gear lave with 3.15 x 2.99 = SLR 9.418
10r80 7th gear clutches die fast on Power adder cars and 3.55 have most shifting into 7th gear right at the 1320.
But using a 2nd gear leave with 3.55 looks to have the most ideal SLR.
What are your thoughts on SLR with 10r80?
Quick math
3.55 rear axle gear
3.31 rear axle gear
3.15 rear axle gear
