Keep my 3.55 or change to 3.15
gimmie11s
SoCal
Murica!
It will take a LOT of power to exceed 143 mph in the quarter. If you are comfortable with 7800 RPM shift points, you may not need 7th.
I will look forward to seeing the OPs car run. A 945 WHP GT 500 barely does it.
What are you talking about? 143mph can be done with 800whp or possibly less. Evolution's gt500??? lol, ok!
OP... if you are making 900whp you will be trapping closer to 150 and you MUST have 3.15's to stay out of 7th gear. My car has gone 147 mph on the 850hp tune and im at the top of 6th gear going through the traps with 3.15 gears. Leaving in 2nd gear is fine.
Jed S.
Irwin, Pa
Jedidiah
2018 Whipple Stage 2 Mustang GT
Proof is in the pudding:
Redline on my car is just about 800rwhp. Dyno sheet is only to bout 7200.
The run:
gimmie11s
SoCal
Murica!
The run:
Not sure which point you are trying to make... ?
Your car looks fast for sure!
Jed S.
Irwin, Pa
Jedidiah
Just proof that 144mph and higher is possible with less than 950rwhp that brucelinc said might not be possible.
Furious18
Nevada
2018 mustang gt, 2018 f150 eb 3.5
I just swapped out my 3.55s for 3.15 in my 18. It made a huge difference with driveability and traction. With 3.55 it bucked and had some shitty downshifts. It all went away with 3.15. 3.55s were blazing my et streets ss at 80+ mph as well. Every shift would blow them off.
Side convo- 700whp averages 140-142 mph with edelbrock 2650 power curve. Beefcakes YouTube has a 710whp car run 9.90s without stall.
