Mustangpursuit
- Jan 17, 2017
- California
- Mustang GT/CS 2019
- Vehicle Showcase
- 1
Hi ,
Not sure if most know, the trunks when opened, they come with these holes at each corner that have a clear circular sticker.
I noticed rust in the center of one and a little in the other. I peeled them off and found out the rust was luckily not the trunk surface, it was some left over sharp loose metal shavings probably from the factory or when they screwed the trunk hinges in? I inspected the holes and checked with a flash light and wiped a little WD-40 around the hole edges. the clear stickers were no good for re-use and had center rust stains anyway.
I just had some left over exterior black vinyl stickers logos and just cut up the right size to just re-cover the holes.
Is this ok for now? or I should be getting some specific clear wafer seal?
