JRZ Suspension Mustang 6th Gen ((S550) 2015- ) JRZ RS Touring ONE Single adjustable
Discussion in 'Suspension/Chassis/Brakes' started by XP Motorsports, Feb 12, 2020.
Thread Status:
Not open for further replies.
  1. XP Motorsports
    First Name:
    sales
    Vehicle(s):
    ford
    Jan 27, 2020
    Longwood Florida
    Occupation:
    Race Car Builder
    0   0   0
    Knowledge gained from racing is integrated in the JRZ RS ONE system. The use of the large shaft creates an optimum fluid displacement through the preset compression blow off valve to control the unsprung mass. A special designed piston is used to filter out the large, high velocity movements seen with suspensions on street applications.
    No need to compromise on performance/comfort due to the large adjustment range. The suspension allows adjustment between smooth street use and aggressive track use. Below you can see the force / displacement graph of a typical JRZ RS ONE.
    With every click (counter clockwise) you increase the damping forces in both compression as rebound making the suspension stiffer. With every click you will notice direct influence on the handling of the car. Therefor adjusting the suspension is very quick and easy.
    JRZ RS ONE
    Single Adjustable
    Adjustable damping
    21 clicks
    Ride height adjustable
    Uses spherical bearings
    Valved for more chassis control and performance
    Fits aftermarket top mounts
    Every click noticeable change
    https://www.xplosiveperformance.com...enS5502015-JRZRSTouringONESingleadjustableKit
    Starting at 2890.00
    Picture is a single adjustable damper JRZ RS ONE Sport.b23b8dd4d42dadd62eabaa4fdf073568.jpg
  2. OP
    XP Motorsports
    First Name:
    sales
    Vehicle(s):
    ford
    Jan 27, 2020
    Longwood Florida
    Occupation:
    Race Car Builder
    0   0   0
    Get free shipping on everything at XP Motorsports till 4/29/20
Loading...
Thread Status:
Share This Page
