JLT blow through Intake for Paxton/Vortech kits
Jeff_oddo
Colorado Springs, CO
Jeff
Mustang GT Premium
Well I finally got some time off work to head down to JLT so the guys there can take measurements and design a heat shield for the 2015 Paxton/Vortech kits. As some know they only offer the blow through pipe and filter for the kit which doesn't include the heat shield. They will be using my car as a test vehicle. Looking forward to helping those out with the Paxton/Vortech kits take advantage of a great intake kit for the car. I'll post up pics when they are done.
Jeff_oddo
Jeff
Mustang GT Premium
Took the car in today. They fabricated a new heat shield from
the air box that comes with the cold air intake kit. They actually cut quite a bit off to get it to fit snug with the intercooler pipes that are in the way. They also fabbed up a new 4" pipe and fitted a new filter. It looks great and they will start producing it very soon to sell to everyone. For now I am going to cut a hole in the back side of the box so I can fit my UPR oil Seperator in the engine bay. It doesn't fit right now due to the box being in the way. So those with the UPR Paxton/Vortech specific oil Seperator will have to fab something up to get it to fit. Other than that it is a great product and I am only seeing about 4-8 degrees above ambient temps with the setup, although the intercooler has a lot to do with the lower temps.
Jeff_oddo
Jeff
Mustang GT Premium
Install pic
Jeff_oddo
Jeff
Mustang GT Premium
Install pic 2
Jeff_oddo
Jeff
Mustang GT Premium
Does your tune need to be refreshed?
I already had the intake kit, all that was added was the heat shield. I'm sure Lund accounts for the larger intake in my tune.
Inigo
P2P Engineering
Denver
Alex
2015 PP GT 6spd
Nice Jeff!
Hey, I have a question for you. Did you need to move the idler pulley position or change your belt size using the 3.6 pulley?
Jeff_oddo
Jeff
Mustang GT Premium
I moved the idler pulley from the SC kit to the spot it called for in the instructions and installed the provided belt from Paxton.
beefcake
Bethel
2018 Ford Mustang
tune should be fine, car should compenstate with the widebands
Process
Pittsburgh, PA
2016 Porsche 911 Turbo S & 2016 Shelby GT350R
MAF Housing is not in that same location on a centri kit, tune revision is not required. You can essentially run intake less, with just the centri blades exposed if you wanted to, or with a mesh screen etc.
Vinny@JLTPerformance
Chesapeake, VA
2015 Mustang GT
Jeff,
Thanks for your time yesterday. Look forward to getting some feedback from you in the coming days so we can move forward on production.
Thanks!
Vinny
kiko1
Miami, Fl
2015 GT auto
very nice.
Jeff_oddo
Jeff
Mustang GT Premium
Jeff,
Thanks!
Vinny
So far so good! The box has a tight fit so it doesn't move around. I'm working on trying to mount the oil separator this weekend.
