JLT Black Textured Cold Air Intake and Custom Tuned nGauge Tuning and Monitoring Gauge - 2015-2016 Mustang GT
Starting at: $854.00
This Cold Air Intake Kit from JLT Performance is a great way to get more power and performance from your 2015 Mustang GT. This kit from JLT will replace your boring factory air box, with a black textured unpainted finish Cold Air Intake which will look great under any 2015 Mustang GT hood. JLT has designed this intake to bolt right on to your new S550 with no permanent modifications. So if you’re looking for a upgrade to increase horsepower & torque in your 2015 Mustang GT, look no further than this Cold Air Intake from JLT Performance.
Kit Includes:
- JLT textured plastic or painted plastic intake tube with PCV fitting and integrated 110mm I.D. MAF housing
- 5"x8" S&B powerstack air filter
- ABS plastic heat shield with weatherstrip
- 2" Silicone coupler
- Clamps and hardware
- Sound tube cap
- Necessary fitting for automatic transmission Mustangs
Features:
- Air Filter Heat Shield
- Larger intake tube opening to fit aftermarket Throttle Bodies
The new nGauge is a digital gauge that connects to the vehicle's OBD2 port, allowing the user to view live data with intuitive datalogging, read/clear codes, reprogram the ECU and do many other things that have never been so easily packed into one device before.
Brand New Dyno, Street and Track Proven Custom Tuned nGauge for your 2015-2016 Mustang GT!
Over the past five years we have spent thousands of hours developing Tunes for both the Manual and Automatic Mustang GT's. All of our tunes are developed on our In-House Dyno and our own Cars.
The Tunes that come with this package are based off the one's used to propel our Mustang GT 5.0L 4V Automatic to a smoking 7.92 @ 173 MPH in the 1/4 Mile.
Pick from 91 Octane, 92 Octane, 93 Octane, E85 Street Tunes, or our 100 Octane Xtreme Race Tunes.
Automatic 2015-2016 Mustang GT 5.0L 4V's will receive the most Advanced Transmission Tuning on the planet! We have spent a lot of time tuning the transmission shift points and firmness on our Mustang GT Auto so you can get the most out of it for either the Street or Track!
ECU Part Number
The "ECU Part Number" is a series of letters and numbers that identifies the program that is in your vehicle's computer. When we custom program an SCT X4 tuning device for your vehicle the ECU Part number is required. This ECU Part Number consists of 13 letters and numbers long. An example ECU Part Number is FR3A-14C204-CPE.
The vehicles ECU Part Number can be found on the computer itself. The computer is located in the engine bay on the front passenger side near the fuse box.
From the factory, your vehicle's computer is calibrated for the masses, designed with the average driver in mind, not the performance enthusiast. This not only leaves valuable Horsepower & Torque hidden inside your vehicle, but it also makes for a mediocre driving experience. The nGauge unlocks your vehicle’s hidden performance by optimizing your vehicle’s computer for Maximum Horsepower, Torque, Increased Throttle Response, Firmer Shifts & even Increased Fuel Mileage!
Gauge Functions
User configurable digital gauges
Display up to 6 gauges at a time
Pick from hundreds of OBD2 signals
Record log files to MicroSD Card
Program warning lights
Built in diagnostics
Daisy Chain up to 7 gauges together
Optional Tuning Feature
Tuning can be enabled by our partner companies
Read and save stock file
Load hundreds of tunes from your MicroSD Card
Support for Ford now
Auto save when you stop logging or lose power
No updater software
Unlimited tunes
Full file flash first time. 4-5 mins
Flash updates under 1 min
main config file sent with the tune
4 or 6 parameter screen mode (to view similar to an Aeroforce gauge)
Hardware Features
2.4" 320 x 240 Color LCD
Resistive touch screen
Touch stylus included
Micro-SD Card
2 Analog inputs
6 Programmable LEDs
Chrome bezel
Brushed aluminum overlay
Adapter Ring Included
Dual T-Slot for pedestal mounting
Thin design to save space
Auto Sleep/Wake with ignition
RS232 and CAN expansion Port
Support for Zeitronix wideband
Light Sensor with auto dimming
Firmware update thru USB or MicroSD
2 High Speed CAN Channels
You get one custom tune loaded onto your device. The custom tune for cars with aftermarket superchargers or turbo's will be required to purchase a remote tuning session.
Remote Tuning Session
They are for required all power adder and extreme naturally aspirated vehicles. This session includes full datalogging support to dial in the modifications done to the vehicle. We will look at the logs and send revisions until the tune is dialed in for your vehicle.
We require full disclosure of the modifications done to the vehicle and will review and suggest changes to be made (if required) before tuning the vehicle. This is to ensure that the vehicle will achieve proper horsepower goals and have the best driveability possible.
The basic process for remote tuning is:
1.We create and send a base startup tune via e-mail along with datalog instructions.
2.You will datalog initial logs for us as instructed. This usually entails and idle, neutral rev, and cruise log so we can review and dial in all part throttle events before proceeding to wide open throttle tuning.
3.After a possible few datalogs and revisions back and forth, we will instruct when we are ready for wide open throttle (WOT) tuning. If a dyno is utilized, it will need to be scheduled with us ahead of time so we can ensure we are available.
100 Octane Xtreme Race (+$100.00)
E85 - Naturally Aspirated Only (+$100.00)
Nitrous (+$100.00)
Cams - Naturally Aspirated Only (+$100.00
Remote Tuning Session (+$350.00)
Kit Includes:
- Sound tube cap
Features:
ECU Part Number
Gauge Functions
No updater software
Unlimited tunes
Hardware Features
Micro-SD Card
2 Analog inputs
6 Programmable LEDs
Chrome bezel
Nitrous (+$100.00)
