Jacking up rear of 2018 Ecoboost vert, did I screw up differential?
spinoodle
Milwaukee, WI
Andrew
2018 Mustang Ecoboost Premium Convertible
2018 convertible Ecoboost premium. I'm a cheapskate so I was trying to put winter tires on by myself. It was going fine until I was jacking up the rear with a hydraulic jack under the differential as recommended here: https://www.cjponyparts.com/resources/how-to-jack-up-your-2015-mustang
As I was jacking it up, there was a loud ping and the car dropped slightly. I believe what happened is the jack teeth around the saddle were not resting steadily and one of them slipped off the edge of the differential cover. You can see a chip bit out of it at the bottom. My question is, how bad did I screw this up? Too my eyes the bottom of the differential does not look level, is it supposed to be? The car still drives fine as far as I can tell. Thank you for any relief you can give to my paranoia.
cerbomark
TN
20 GT PP2. 24 Ram BTS, 21 Mach1 (Sold)
Looks like you are OK, keep an eye out for leak just to be sure.
cerbomark
TN
I don t see any "clean" mark along where you say it s uneven to indicated it moved. Probabaly like that always.
barron64
Auburn, AL
2018 Mustang GT convertible PP1, 6sp, 2006 Toyota Tundra Dbl Cab 4x4, 2009 Acura MDX, 2007 Toyota FJ Cruiser
Use a small 2"x4" wooden block between the jack cup and whatever you are jacking up. Helps cushion and grip without damaging anything.
spinoodle
Milwaukee, WI
Andrew
Thank you everyone! No leaks and driving fine. I'll post again if I encounter any issues.
WD Pro
United Kingdom
Lime GT
The differential rear flange/cover is not level to the ground between the lowest two cover bolts. IOW, that's normal Your diff looks fine to me, according to your photo.
This, and just to confirm it with a photo :
WD :like:
Edit for a spelling ...
Johnnybee
Canada
2018 convertible
Get yourself a pinch weld puck and jack up each wheel individually by their respective jack point. Yes, it takes a little longer but dead solid and no concerns about damage.
cerbomark
TN
I use a regular (Walmart, Sport authority etc) hockey puck. Don t really need the cut, it does it itself when you use it. Cheaper too.
Johnnybee
Canada
2018 convertible
That’s an option too. I bought a magnetic aluminum one on Amazon for the equivalent of about US$10. Don’t have to worry about it failing. Plus I have lots of room for tools and so on.
