J&M Products / Hotpart.com Newest Parts - MagneRide Specific Stainless Steel PTFE Lined Brake Hoses
Hotpart.com
San Luis Obispo, CA
2002, 2006, 2015 Mustangs
J&M Products direct fit D.O.T. certified PTFE lined brake hoses. These brake hose assemblies use true OEM style direct replacement non-universal fittings to achieve proper factory hose routing and fitment. Expansion of stock rubber hoses causes a spongy brake pedal feel and loss of initial braking force. Installation of our PTFE-lined stainless steel hose assemblies will give your car a firmer pedal, quicker braking response, and easier brake modulation. Hoses are tested to 3000 psi to guarantee a leak free hose assembly. Best of all these are made by J&M Products right here in the USA.
Stainless Steel Features and Benefits:
  • Direct OEM Fit each fitting is of OE design so NO adapters are necessary.
  • No volumetric expansion (hose swelling) for powerful braking and amazing ā€˜feelā€™
  • Suitable for all applications including extreme racing.
  • Exceeds the latest DOT standards backed up by independent laboratory reports.
  • Trivalent zinc plating exceeds DOT salt spray test.
  • Design allows high temperature operation and longer life.
  • Every hose is pressure tested to 3000 psi. (207 Bar)
  • Quicker brake response. Better brake modulation.
  • Every hose is stamped with U.S. DOT registered number.
  • Clear Outer protective covering.
Fits: 2018, 2019, 2020, 2021
Fits: 2018-2021 ā€“ Ford Mustang GT & Ecoboost With MagneRide Suspension
Smunczen
Atl
Scott
2020 mustang gt pp2
I add those to my buy list.
KermiStang
Australia
AJ
2019 Mustang GT N4G
Are there any coupon discounts running?
TeeLew
So Cal
Tim
I've got these lines (and love them), but now I'm changing over to bigger calipers. What size crush washers do you use? I want to get a bunch of freshies on hand.
Hotpart.com
Hotpart.com
San Luis Obispo, CA
We have them made to our specification but any thick M10 crush washer should work. If you can't find any PM us with your address and I can have shipping send some out for you.
TeeLew
So Cal
Tim
Thanks for the response and offer. I've got 50 M10x18x2.0 crush washers on the way for less than $10, so I'm good.
