EruptionGT
- Mar 15, 2022
- Metro Detroit
- 2022 GT 10 speed Performance Pack
1,800 miles on my 2022 Eruption Green and I have the famous BBQ tick after doing my first oil change. Usually when the cars hot at idle, you’ll hear that little spark ignitor sound similar to a stovetop or a barbecue. It does not seem to be making any knocking or deep sounds, just that high pitched clicky sound. I posted some YouTube videos at the end of this comment to show exactly what it sounds like.
Since there appears to be hundreds of pages of BBQ tick on the different social media platforms, I’m wondering if anyone has developed a factual explanation as to what exactly it is and why?
I’ve heard many different theories.
1) piston slap (heard it was mainly an issue on the 2018-2019, and how some engines depending on their individual clearances sometimes had Piston to wall contact due to thermal heat expansion in the piston and aluminum block),
2) solenoid and oil pressure related - the 2018+ have a computer controlled oil bypass solenoid to lower oil pressure at idle to run more efficiently, and some theorize that the hydraulic lash adjusters at low oil pressure at idle are not fully inflated which causes a tiny gap between the hydraulic lash adjuster and rocker arm. When it does cycle it makes contact and “ticks”. When oil pressure goes up and you increase RPM, the HLA fully inflated and makes contact with the arm, and the ticking usually stops.
3) just run Liquimoly Ceratec as almost everyone I’ve talked to says it quiets the Gen 3 bbq tick and don’t think about it until if and when it blows up.
What are your thoughts on all of this? Anyone have special intel from a master tech or someone high up at Ford who’ve spilled the beans on what exactly is going on?
clip 1:
clip 2:
clip 1:
clip 2:
