It depends on the model of Mustang and it depends on which dash setting you have.How's the traction control tuned in the Mustang? Will it kick in at the very first sign of traction loss, like an overly cautious nanny? Or will it allow you to play a little before it steps in?
Can you get a bit of power oversteer, within reasonable limits, without turning it off?
Its a lot less intrusive than GM's stabilitrack, you can do burnouts for hundreds of feet with TCS off but stability control on, it only kicks in if you go too far sideways and I think that is judged by steering wheel angle. So basically if your steering wheel is turned too much it will kick in and stop you. I do have a tune, non stock tire sizes and pp1 though. A I usually have the shifter in S paddles activated in drag mode when actually doing rolling burnouts.How's the traction control tuned in the Mustang? Will it kick in at the very first sign of traction loss, like an overly cautious nanny? Or will it allow you to play a little before it steps in?
I thought I read somewhere that the Mustang is programmed to let you play a little bit and then kick in to create the illusion of a wild beast before it kicks in. And yes, you can definitely get power oversteer without turning it off! The back tires will break away before it kicks in.How's the traction control tuned in the Mustang? Will it kick in at the very first sign of traction loss, like an overly cautious nanny? Or will it allow you to play a little before it steps in?
power steering pump labored ??
I dont think thats valid with electric steering which we have, although the tire part is trueOften called "dry steering", it's not good to turn your wheel without moving forward or backwards. Also harder on the tires. Saying all this, it's actually a difference many will never ever notice.
I guess I also should have disclaimed the previous post never happened and was a sarcastic remark 100%
There's no way I can sugarcoat it.Stability control would have saved me on my accident
Stability control absolutely wouldnt have allowed me to do what I did lol, I tried hundreds of times it kicked in way too early on that car.There's no way I can sugarcoat it.
With your above stated attitude it's probably guaranteed that stability control would not have been enough help. If it had saved you that time, it probably wouldn't have been enough the next time.
What would have saved you would be for you to have stopped thinking that every piece of pavement is your personal hundred-yard drag strip. Or that the throttle pedal has only two positions - either on the floor or with your foot completely off of it.
I only had to go about 120 posts deep in your list of postings before I found these two gems (emphasis mine). Stop expecting the car to cover your a$$ while you refuse to develop any sense of self-preservation.
Norm
Listen to the man.I dont think thats valid with electric steering which we have, although the tire part is true
All you know is that you didn't duplicate it. Somehow, I doubt "hundreds", let alone on the same stretch of road.Stability control absolutely wouldnt have allowed me to do what I did lol, I tried hundreds of times it kicked in way too early on that car.
FWIW, I only went "one" hundred deep. But I can dig another 350 posts deeper if you'd like me to.On my mustang its alot better. Also kind of weird you searched through hundreds of my posts but ok..
58* morning, 7:30 am cruise after coffee, pulled out onto "mainstreet" from side street during the right turn the rear lost traction..Bye Pirelli..#NewPS4S.How?
