TorqueMan
- Aug 24, 2017
- St. Jacob, IL
- 2017 EcoBoost Premium
This video popped up on my Youtube feed (I guess I watch a lot of car/tech videos). It's from "Tuned By Nishan," which I've never heard of before now. These guys posit that many ecoboost engine failures are related to exhaust gas reversion, which is caused by running high boost on the relatively small factory turbo.
Exhaust gas reversion occurs during intake/exhaust valve overlap. The pressure in the exhaust manifold is so high that a portion of the exhaust gases that should exit the cylinder either remain, or are forced back in the cylinder by the high pressure in the exhaust manifold. They say they've measured pressure in the exhaust manifold that exceeds pressure in the intake manifold, which is pretty remarkable. The supposition is that if enough hot exhaust gas remains or is forced back in the cylinder during valve overlap (end of exhaust stroke/start of intake stroke) they can retain enough heat to cause a preignition event as they are compressed along with the fuel/air charge.
NOTE: The videographer says "detonation," but I believe he means preignition. Detonation by itself is rarely the cause of internal engine component failure.
BTW, if this claim is proven correct exhaust gas reversion may also explain why many 2.3 engine failures occur on cylinders 2 and 3. Watch the video to see why. (I know it's long, and there is a lot of repeated information, but watch it all the way to the end; it's worth your time.)
