- Sep 14, 2020
- Wellington, FL
- Jake
- 2022 F-150 RCSB 5.0
Hey all!
Livernois Motorsports just released their Intake Manifold Adapter Kits for the 2021+ Ford F-150’s!
Finally, you can install better performing intakes on your F-150, such as the 2018 Mustang GT or GT350 Manifolds. With more custom tuning options becoming available, these are perfect for those looking to keep it N/A, but need more power!
Since Ford dramatically redesigned both the cylinder head, throttle body, and many other engine components on these trucks, they essentially made them incompatible with current high-performance intake manifolds on the market for the Gen 1-3 Coyote engines, such as the Ported 18+ Mustang GT Manifold.
These kits include EVERYTHING you’ll need to make a correct intake swap on your truck…
Including :
- (2) lower head adapter plates
- (2) upper head adapter plates
- (16) OEM-Grade Intake Seals
- (20) head adapter plate bolts
- (4) fuel rail adapter lower inserts
- (4) fuel rail adapter upper inserts
- (4) fuel rail adapter lower bolts
- (4) fuel rail adapter upper bolts
- (2) IMRC lock out plates
- (1) throttle body adapter
- (1) OEM-Grade Throttle Body Seal
- (4) throttle body adapter bolts
- (1) OEM-Grade PCV hose
Necessary Vacuum Caps
The kits are available with and without intake manifolds included, incase you have your own OR want to get a ported version from 1320 Junkie to get even more power out!
Check them out here!
SHOP NOW | Livernois Motorsports Manifold Adapters
Of course, if you have any questions or want to get something on order, feel free to reach out to any one of us here at Lethal Performance!
