Bump- would like to know this as well. Looking to build the motor and go forced induction myself however need to know if the GT injectors such as these will fit the v6. http://www.americanmuscle.com/mustang-ev6-47-injectors.htmlAnyone know what size injectors we have in our v6.
GT injectors will fit.Bump- would like to know this as well. Looking to build the motor and go forced induction myself however need to know if the GT injectors such as these will fit the v6. http://www.americanmuscle.com/mustang-ev6-47-injectors.html
Do you have GT injectors installed and functioning?GT injectors will fit.
I don't have them installed no sir, but I've been told by Jack from JMP (builds turbo kits for our cars) that GT injectors will work fine.Do you have GT injectors installed and functioning?
I mean, they both are EV14 (conical spray with 14mm diameters upper and lower) and they are both USCAR connectors. So they have the correct spray pattern, have the right diameter to physically fit in the intake/fuel rail, and will connect up to the electronics.... but the V6 uses the compact (like 40mm) style and the GT uses the standard (like 60mm). How can the upper intake manifold fit over the fuel rail and seal to the lower manifold with the rail sticking up another 20mm?
