I'm about to enhance my MT82, any concerns?
Discussion in 'Transmission & Drivetrain' started by bl4d3runn3r, Apr 11, 2018.
  1. bl4d3runn3r
    bl4d3runn3r Well-Known Member
    Vehicle(s):
    Blu Fury
    Mar 22, 2017
    Chicago
    134
    Hi Guys,
    I'm not very happy with the MT82 on my 2017 GT base model. It feels clunky and not really smooth. Also my clutch smells burnt quite often. Yes I know how to drive stick, driving stick since 1999.
    So I wanna replace the Clutch, Flywheel, Throwout bearing and the hydraulic clutch line. I also would like to install the Barton Hybrid 3 shifter and replace the transmission oil with BG Synchro Shift 2.
    I want to order the following parts:
    McLeod Street Pro Clutch
    McLeod Racing Lightened Steel Flywheel
    McLeod Stock Style Hydraulic Throwout Bearing
    Steeda Heavy Duty Braided Hydraulic Clutch Line
    Barton Hybrid 3 Shifter - MT-82
    Is anybody using such a combination? Anything else that I would need to make that work? I hope I can get a less noisy, better daily drivable with these components.
  2. El_Centenario
    El_Centenario 5L V8PWR
    First Name:
    David
    Vehicle(s):
    '15 Mustang GT Triple Yellow
    Jun 11, 2015
    Victorville , CA
    555
    122
    0   0   0
    I did the Barton shifter and the oil you mentioned. Solves most of the issues. Do that first and see if you like it then. I Will change out clutch when stock goes out. 62k miles so far and still good. Pedal only feels spongy after 4 back to back wot runs.
  3. El_Centenario
    First Name:
    David
    Vehicle(s):
    Jun 11, 2015
    Victorville , CA
    555
    122
    0   0   0
    Forgot to mentioned I replaced the clutch pedal spring with one from Steeda. Best $15 spent! Try that too!
  4. Jeff's FRC
    Jeff's FRC Well-Known Member
    Vehicle(s):
    2015 DIB GT
    Sep 2, 2015
    Carpentersville, IL
    948
    436
    Rating:
    100%
    1   0   0
    MGW, Steeda spring, braided clutch line, and Amsoil fluid in my MT82. Love it!
  5. OP
    bl4d3runn3r
    Vehicle(s):
    Blu Fury
    Mar 22, 2017
    Chicago
    134
    I already replaced the clutch spring. Actually feels worse. Pedal feels pretty spongy. Is it normal to have some play in the clutch pedal?
    My Mustang makes all sorts of noises which I can track back to the transmission, if I disengange the clutch quickly I get a weird noise, sounds like fluid being pumped quickly into the throwout bearing.
    I love the Mustang GT, but the transmission felt weird from the first day on. Dealer says that everything is OK. Clutch started to smell burned very quickly and some gears sound grindy, like there is a noise coming from behind the dashboard in 3rd gear for example, other gears don't have it.
  6. Braski
    Braski Well-Known Member
    Vehicle(s):
    2015 Blk GT Prem PP
    Feb 4, 2015
    Lancaster, PA
    1,211
    359
    Garage Profiles:
    I'm looking at doing a similar upgrade. That looks like a winning combination!
  7. Bridgie
    Bridgie Well-Known Member
    Vehicle(s):
    2015 GT fastback. PP, 50th trim, Black
    May 25, 2015
    Raleigh
    81
    Do these too....
    Steeda shifter base bushing bracket and transmission mount bushing insert.
    I would expect from all your mods.. There will be an increase in NVH.
    A Roush or Corsa extreme Cat back and H Pipe will fix those issues..!!
  8. Grinder67
    Grinder67 Well-Known Member
    Vehicle(s):
    2017 GT
    Oct 8, 2017
    Wisconsin
    99
    BG fluid and weighted shift knob helped mine a lot.
  9. OP
    bl4d3runn3r
    Vehicle(s):
    Blu Fury
    Mar 22, 2017
    Chicago
    134
    Posted the same in allfordmustangs.com and somebody said that the McLoed products are not very good in quality? Is that true? Any alternatives for a Street car?
  10. El_Centenario
    First Name:
    David
    Vehicle(s):
    Jun 11, 2015
    Victorville , CA
    555
    122
    0   0   0
    If that is the case then it might be your trans having issues. I Pedal should not feel spongy with the steed spring. Play? Maybe a little, I have about 1/2" of play but pedal is firm all the way down. Have you done a fluid flush? Maybe you have some air in the line.
  11. draconis123
    draconis123 Well-Known Member
    First Name:
    Michael
    Vehicle(s):
    2016 GT
    Jan 1, 2016
    188
    44
    0   0   0
    MGW shifter and removing the drastically improved everything for me. I didn't get the steeda spring. Try removing it and going without for awhile. Makes the pedal heavier but I don't have any issues, although extended stop and go traffic can get tiring. It makes the clutch significantly more predictable.
  12. ForYourOwnGood
    ForYourOwnGood Well-Known Member
    Vehicle(s):
    2017 Grabber Blue 5.0
    Jun 28, 2016
    Central MA
    911
    304
    Rating:
    100%
    1   0   0
    I also have the burnt clutch smell quite often and I swear once in a while it slips for a second even on normal shifts. I made sure to follow the break in procedure and it seemed to make no difference.
    I've only ever had manual sports cars, over a dozen of them now some making nearly 3x the HP this mustang is and never had a clutch that feels like this. Even my manual 2006 dodge ram lasted 290k miles with at least half of that towing a 5500lb trailer with Harleys in it (and I sold it still in good working order).
    This clutch just makes me feel like it will go at any time, mainly because of how it engages differently on each and every shift. I wonder if the 18+ clutches can be retrofitted.
  13. yote41
    yote41 Well-Known Member
    Vehicle(s):
    16 gt
    Aug 16, 2017
    pa
    525
    87
    Rating:
    100%
    1   0   0
    im sure the 18 clutch is same shitty material...
  14. ForYourOwnGood
    Vehicle(s):
    Jun 28, 2016
    Central MA
    911
    304
    Rating:
    100%
    1   0   0
    Well its a twin disk so the material isn't as important. Supposedly it feels a lot better to use though, I've yet to drive one myself.
  15. JETZGT
    JETZGT JETZ GT
    First Name:
    Jason
    Vehicle(s):
    DIB 2016 GT PP SC
    Dec 20, 2017
    Illinois
    Following as my car has 4100 miles on it. 2016 GT supercharged. I also have some slipping and that wonderful clutch smell occasionally.
    Looking at the Exedy Stage 3 w/ lightweight flywheel. Seems equivalant to the one your looking at.
    Whos doing your install Jeff?
  16. 347CobraII
    347CobraII Well-Known Member
    Vehicle(s):
    2015 GT
    Jul 16, 2015
    iowa
    783
    98
    0   0   0
    NO oil, clutch line, helper spring, shifter going to fix it just band-aid. Not everyone having the problem either but some have. Most part its clutch not releasing fully especially at high RPM and then it gets worst overtime in tell trans is hurt. Hint why Ford using dual disc in GT350 and 2018 mustang.
    There is big difference driving car with dual disc clutch
  17. georgiarocker
    georgiarocker Member
    Vehicle(s):
    2016 Roush Warrior S/C
    Mar 25, 2016
    Georgia via Germany
    I replaced my slave cylinder assembly with the mcleod recently. It's (supposed) to be a direct replacement for the stock one (with a beefier spring). It's not necessarily. Lesson learned... the input tube connector did not extend out the hole in the transmission as far as the stock one. Make sure you replace the plastic insert into the tranny and install the plastic elbow connector BEFORE reinstalling the transmission. If the elbow connector doesn't snap onto the feeder tube properly, you may have to bend the tube slightly. I made the mistake of reinstalling the transmission before checking for proper fitment. Big mistake.
Loading...
Share This Page
