Nctong01
Nctong01
Kentucky
2017 Mustang D1X GT, 2018 GT350, '17 Turbo Silverado, '99 Turbo Integra
I think she was diagnosed when she was 14. She has a nerve condition called crps. It causes her nerves to be very painful at times. It has luckily not spread very much and her flare ups are pretty rare, letting her live a fairly normal life. But you always have the fear in the back of your mind that it will get worse and spread, especially when the flare ups happen.
She’s also had to give up hobbies she loved and I’ve seen how hard that can be on someone.
I hope your condition will let you enjoy your life for years to come. It at least has to behave till you run a 7 lmao
Ah man I can only imagine being diagnosed at that age. That's one aspect I felt "lucky" for...although Im not old, I've lived a decent live. But thank goodness it's managed well on her end. I understand the fear of things getting worse; I can empathize. I have a little impatience with this build in the back of my mind with that thought along.
If I go downhill fast I'm towing this bitch up the road to the local tuner shop, paying to get it done and running, no if and's or buts :cwl:
Nctong01
Nctong01
Kentucky
Nitrous in, tank mounted. Doesnt look like Ill be able to keep the carpet unless I just butcher it. I'm going to have to run a square 5 gallon ice tank on the other side as the wheel well has the airlift motor and manifold, and I'd rather not reconfigure them, leaving a bunch of holes where the lines were ran. But hey...I figure if I'm adding weight, it'll be fairly equal and as far back as I can get it. Wont be running lines or wiring until the end of the build.
Starting pulling out the interior. ETA on engine internals is 1.5-2 weeks. Got some tint in so will get that done probably this weekend. Slowly but surely.
Nctong01
Nctong01
Kentucky
Also....if anyone runs fathouse fabs cage and reads this....could they shoot me a line? I'm worried about some of the bar placement in the back interfering with the air lift tank. I know it'll be close.
Crowd Hunter
Tennessee
$hitbox
I came in expecting to see a 7 second time lapse video. Nice build!
Nctong01
Nctong01
Kentucky
Ahah maybe I'll do a little 7 second time lapse at the end as a parody :p With all the backorders right now though I have a feeling this is gonna take a minute.
So, I've officially ordered 3 things twice, forgetting I had already purchased them :cwl: In order to keep myself in line I'm going to update the parts I've ordered here, crossing out those I've received.
Block
Billet rear main cover with seal
Oil squirter block offs
Oil pump with billet gears
Manley I beam Rods (will be selling these when I get them)
Boostline Rods
Manley forged pistons with top coating
Total seal steel rings
Clevite bearings
BOSS Crankshaft (will have this for sale when it's in if anyone needs one)
Callies 3.65 4340 Crank
Dry Sleeves
ATI Super Damper
Light weight water pump pulley (yes...I know. Cheap if it adds any kind of initial throttle response)
All ARP engine hardware (main studs, head studs, cam tower bolts, cam phase bolts, crank pulley bolt, water pump pulley bolts)
Oil tube spacer for ARP Main studs
Kinetic Crank Saver Stud Kit
Aftermarket oil pan, baffled and +1.5 quart capacity
Head
MMR Valve springs+retainers
Ferrera Valves
Set of OEM timing chains
Head cooling mod (not sure about this...a lot of failures I see are cylinder 8 though so I didn't think it'd hurt anything)
Cometic 5.2L MLX head gaskets
Billet secondary tensioner bracket-XHD secondary chains and gears
Billet Primary chain tensioners
Fel-pro timing cover gasket kit
Intake manifold gaskets
Exhaust manifold gaskets
MHS 5.0L Coyote Xtreme Race Turbo Cams
VCT Phaser Delete
VCT Valve cover block offs
Billet chain guides/arms
87mm Throttle body
Viton Valve seals
GT500 valve covers
AN valve cover inserts for catch can
Turbo Setup
Garrett G57 2000 88mm w/ 1.4 A/R
Precision Racegate BOV
Frankenstein Air to Water bulldog manifold
PNR 5 gallon air to water tank
BPS Billet 16 AN Pass through
Trans+Rear End
SFI case TH400 rated to 2200-2300 wheel
Coan Converter
All necessary accessories for TH400
DSS CF driveshaft with billet yoke
G Force 9 inch rear end w/3.7 gear
Body/Chassis
Steeda Front Bumper Bar
BMR K member
BMR Billet Aluminum Vertical Links
Suspension/Brakes/Wheels
JPC line lock
AED Billet knuckles
Baer rear drag brakes for AED knuckles
Baer front drag brakes
Bogart 11.5" beadlocks
Hoosier 30x10.5-15 Radials
Hooser front skinny bias ply
Kelltrac front coilover
Kelltrac rear shocks
Kelltrac camber plates
BMR Adjustable Toe Links
BMR Adjustable Delrin Camber Arms
BMR Camber Lockout
BMR Upper shock mounts
BMR Standard Lower Control Arm Bearing Kit
Energy Suspension Poly rear spring isolators
UPR 3/8 Billet spring space
UPR IRS Subframe bushing lockout kit
UPR Billet Subframe connector
UPR IRS Subframe alignment kit
Cooling/Accessories
BL fab radiator overflow/catch can
SVE radiator
(returned, going with a different setup)
Motion Raceworks steering column kit
Motion Raceworks parachute setup
Nitrous system (will probably run just a 50 jet)
Nitrous Outlet purge kit
Nitrous outlet sunglass cubby controller
Fuel pumps
ID 2600x injectors
DivisionX Mustang Triple Pump Fuel Hat Manifold (thanks @illtal )
Lethal Boost a pump
Thermostat housing delete
Exterior
Window, headlight, tailight tint
Anderson Composites CF Doors
MMR Drag Wing
MMR Carbon fiber trunk
Trackspec hood vents
Wrap material
BPS Mirror Block off plates
Interior
Watson center panel delete
Sparco Steering wheel
(returned, bought an innovative racecraft wheel)
CORNYOTE
Oklahoma
Alex
2019 GT
Aha I don't know if it's a norm YET. If I wasn't super type A and was willing to spend a stupid amount of money to hit it I'd be just fine with 8's. I admit I'm a little dumb for being set on that goal :cwl:
I mean the top 15 in the US are all 7's so it's coming more and more the norm. Midnight has a full 10 speed car with AC and all running high 7's.
Should be a fun build though. I thought I'd be happy with 9's but turns out goals are on a sliding scale šŸ˜‚
Nctong01
Nctong01
Kentucky
Lmao, exactly why I skipped 8's ahahah
I mean, at the same time...compare that to the number of 8 and 9 second cars. Dime a dozen in comparison.
Nctong01
Nctong01
Kentucky
So I ended up ordering some Hoosier 27.5 front runners bias ply's along with 30x10.5 Drag radials...however I think I'm going to go bias ply all around despite the auto.
Reasoning is I actually think the setup will be able to take at least 1700 wheel being sleeved...that, the nitrous off the hit, a g57 88mm turbo which should result in "good" spool times, 3.7 or 3.89 rear end, and the fact that the air suspension is subpar, I feel like radials would absolutely not bite as well as I'd like. I already had issues on my previous setup, albeit on an unprepped track.
Any big power auto guys have any advice?
CORNYOTE
Oklahoma
Alex
2019 GT
The 30" tire will be tight. I run a 315/60R25 (29.9") ET Pro and they're VERY snug. That's on a 15x11 wheel with 8.5" backspacing to get it to tuck. Not sure what your wheel offset is, but I had to trim some of the inner fender liner away for clearance. I also had to run a T-Bar style upper shock mount to clear the wheel barrel. If you're looking to be successful on the street aside from 100 rolls, you may want to look into a weight bar too. every bit helps lol
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Id go with at least a Callies crank and def radials.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Why radials? I noticed most of the serious street guys are running bias ply's.
Nctong01
Nctong01
Kentucky
Was the the t bar because of the width or height? I appreciate the heads up, I may got a bit smaller. Are you running aed knuckles?
Nctong01
Nctong01
Kentucky
You’re the man, Crank it is…question…but no flames lol…I know there can be some negative buzz with them. Mmr crank no good?
CORNYOTE
Oklahoma
Alex
2019 GT
Width. And yes AED knuckles.
I talk a little about some of the stuff on YouTube when I did the install.
9 - JLT Performance
