If Discount Tire owns Tire Rack + 285 or 295 on 10" wide wheel?
stungjoe
Dallas
Joe
2019 Bullitt
Why can't you send Tire Rack tires to a Discount Store for mounting? With Tire Rack you basically get a two year certificate for free. The tires are the same price at both places.
I have a set of Velgen Classic5's coming with a 20x10 for the front. Should it be 285/30x20 or will a 295/30 work better? I want the overall diameter to be closer to the 315/30 rear tires (11" wheel) that's why I'm wanting the 295 width.
Onewolf
East Tennessee
2023 Ecoboost Premium Convertible
Last week I had Discount Tire mount the tires I bought from Tire Rack on my new Steeda wheels.
stungjoe
stungjoe
Dallas
Joe
2019 Bullitt
Discount isn't listed on the Tire Rack website. I guess that's what I get for ass-u-ming...haha Thanks for the info!
galaxy
St Louis
'17 GT350
Discount owns TireRack and will match what may be on the site, along with any benefits; or thus they did for me. I get the question, just don't see the need to buy from TireRack. If you have a Discount, just go there and get them. I just went through this and the OTD cost was the same regardless.
stungjoe
stungjoe
Dallas
Joe
2019 Bullitt
I was wanting the added assurance of the cert.s offered by Tire Rack. Granted it's two years instead of three but it's free instead of a 10% premium for the Discount cert.s If Discount matches this then I will be more than happy to buy from Discount...in fact I prefer to since the prices are indeed the very same on their respective websites.
Joshinator99
Massachusetts
Josh
2022 Mustang GT Premium, 2017 Camaro 2SS
I wouldn’t go bigger than 285 on a 10” rim IMO.
TonyHawk
Bloomington, Indiana
Tony
2019 Mustang GT PP1, Roush Stage 2 SC kit, Roush axel back / x-pipe, chin splitter, aero foil and side scoops, GT350R wheels
You can run 305/30R max all around. See the attached. I run staggered but have 305/35Rs on the rear using a 19x10 wheel.
rxryanm
KY
2019 GTP PP1
I've always operated that if you're staggering, you go down in aspect ratio from front to back - so a 35 series on the front if you're running a 30 on the rear. But a 285/35 puts you at 27.8 inches tall and that's a bit tall imo. But I'm also on a square setup so I don't have to worry about that lol
285 is typically the recommended max width for a 10" wheel - anything bigger usually leads to a less handling oriented setup as it introduces some slop due to bulge.
All I'm seeing is 305 on a 10.5" wheel, no mention of a 10" wide wheel period. Which makes sense as Ford doesn't offer a 10" wide wheel from the factory.
Onewolf
East Tennessee
I must be reading that document wrong, because I don't see any indication they say 10" wheel and 305 width tire.
GT350 19-in. x 10.5-in.
aluminum alloy, Michelin
Pilot Sport Cup 2
295/35ZR19, front; 19-in.
x 11.0-in. aluminum alloy,
Michelin Pilot Sport Cup 2
305/35ZR19, rear
GT350R 19-in. x11.0-in.
carbon fiber, Michelin Pilot
Sport Cup 2 305/30R19
front, 19-in. x11.5-in carbon
fiber, Michelin Pilot Sport
Cup 2 315/30R19 rear
19 in. x 8.5 in. 255/40R
W A/S; 20 in. x 9.0 in.
265/35R W A/S;
Performance Package
(front) 19 in. x 9.0 in.
255/40R, (rear) 19 in. x 9.5
in. 275/40R Y Summer
Performance Package
Level 2 (front) 19 in. x 10.5
in. 305/30R, (rear) 19 in. x
11.0 in. 305/30R Y Summer
shogun32
Northern VA
The math says /35 on the front.
TonyHawk
Tony
Pilot Sport Cup 2
305/35ZR19, rear
265/35R W A/S;
Performance Package
Performance Package
It doesn’t. Just a reference to the max tire width
Joshinator99
Massachusetts
Josh
I just bought Velgen VF5s in 19x10 front and 19x11 rear. I’ll be running 275/35/19 front and 295/35/19 rear. You’re much better off to be slightly stretched than slightly bulged as @rxryanm pointed out. Healthy difference in handling between the two.
stungjoe
stungjoe
Dallas
Joe
2019 Bullitt
As for the slop; I have the Steeda front and rear sway bars. Front in the med-hard (3rd) hole and the rear in the full soft. I could move that up one to the medium setting to induce some oversteer. Will this counter the slop? I'm ass-u-ming (again) that the slop might manifest itself as understeer with added sponginess for good measure???
I've played with that darn tire comparison calculator so much lately my eyes are numb! :)
A couple considerations I'm dealing with. I'm getting a s/c and I want the most tire out back I can get. I originally wanted a square 305 on 19x11's but wasn't sure I would be able to tuck the front tire in up top w/out camber plates.. I already have a square set up now w/ 275's on the factory 19x9.5 Bullitt wheels (PP1 specs) so the extended studs and slip-on spacers are already in use.
The next thought was to go w/ 20's but was disappointed to learn the 305/30x20 would lower the car almost 5/8" ( I think that was the number). I have headers now and can't really see the car getting much lower w/out causing all kinds of chaos under there.
In the world of 20" tires, the 305's cost considerably more than the 315's. The 315/30 will keep me near my 27.7" (I think it's actually 27.4 for the 315/30) OA tire diameter so as not to lower the car any more than it is now. Once again the rear of the S550 is very accommodating. It's the darn front end throwing the monkey wrench.
WItoTX
Houston
Kyle
'17 GT350
You don't have any bigger contact patch with a wider tire. All you get is more weight and reduced responsiveness.
If that sort of thing floats your boat, go for it. Also, discount and tire rack are remaining 2 completely separate companies.
stungjoe
stungjoe
Dallas
Joe
2019 Bullitt
Can you explain this? If that is the case then I should just stick with the 275's?
