I have A 2019 GT Flat Spots on the tires?
Discussion in 'Wheels & Tires' started by Bernie D, Nov 8, 2019.
  1. Bernie D
    Bernie D Member
    First Name:
    Bernie
    Vehicle(s):
    2019 Mustang GT
    Sep 17, 2019
    Pittsburgh,Pa
    I have A 2019 GT convertible with 20” wheels. How much air should I put in my tires while it’s in winter storage so it doesn’t get Flat Spots on the tires? I was told 50 Lin’s then 90 lbs.
  2. TheSnowmanMafia
    TheSnowmanMafia Well-Known Member
    First Name:
    Andrew
    Vehicle(s):
    2019 GT Premium
    May 26, 2019
    Denver, CO
    196
    75
    0   0   0
    If you're THAT worried about flat spots then put it on jack stands.
    2morrow likes this.
  3. NoVaGT
    NoVaGT Well-Known Member
    Vehicle(s):
    2019 PP1 GT Kona
    Sep 29, 2016
    Northern Virginia
    3,724
    2,308
    Rating:
    100%
    1   0   0
    Just take it out when the roads are clean & clear.
    And FYI, never, ever has there been a thread where a poster has complained about flat-spotting their tires while the car was stored.
    Methinks it's an old-wive's tale, and nothing to do with reality.
    2015 Silver GT and barkingspud like this.
  4. OP
    Bernie D
    Bernie D Member
    First Name:
    Bernie
    Vehicle(s):
    2019 Mustang GT
    Sep 17, 2019
    Pittsburgh,Pa
    That’s not an answer.
  5. cosmic charlie
    cosmic charlie Well-Known Member
    Vehicle(s):
    2019 Steeda Streetfighter Q850 NEED FOR GREEN, 2016 Focus RS (frozen white), 2016 Focus RS (stealth grey), 2014 Ford F150 Crewcab, 2015 Porsche Boxter GTS, 2013 Mercedez Benz ML350, 2003 Mercedes Benz C32AMG, 1989 Honda CRX Si Turbo
    Sep 13, 2018
    Sunny Florida and Taxachussettes.
    413
    306
    0   0   0
    Over the years I have had cars parked over long periods of time and never had any problems. The only thing I do is make sure the pressure is maintained.
    If you are really worried you could get these from Raceramps.
    https://www.raceramps.com/car-storage/ramps/p/flatstoppers/
  6. FDHog
    FDHog Well-Known Member
    First Name:
    Frank
    Vehicle(s):
    2019 GT RTR
    Oct 27, 2019
    NJ Shore
    91
    90
    Occupation:
    Retired
    0   0   0
    Ain't gonna happen. Don't worry about it.
  7. Andy13186
    Andy13186 Well-Known Member
    Vehicle(s):
    2018 Mustang GT 10speed
    Sep 19, 2018
    1,010
    320
    0   0   0
    I think dealers put them up to 40 psi, but flat spots should be gone within a heat cycle I would think.
  8. 2morrow
    2morrow DesignR/DriveR/RiceEatR
    First Name:
    Todd
    Vehicle(s):
    '16 Mustang GTPP
    Nov 15, 2015
    415/707/925/530/916
    4,452
    2,863
    0   0   0
    I would never put 50-90 lbs of air in a street car tire.
    If you are really worried about this then the jack stand solution is your best way to go for medium to long term storage.
  9. FDHog
    First Name:
    Frank
    Vehicle(s):
    2019 GT RTR
    Oct 27, 2019
    NJ Shore
    91
    90
    Occupation:
    Retired
    0   0   0
    One of my corvettes sat outside all winter under a cover. Never moved and had it with both runflats and all seasons and never had a problem.
  10. Bikeman315
    Bikeman315 Well-Known Member
    First Name:
    Ira
    Vehicle(s):
    2019 Mustang GT/CS
    Apr 12, 2015
    Myrtle Beach, SC
    2,619
    1,796
    Occupation:
    Retired
    0   0   0
    OK Bernie, calm down. We are all just trying to help.
    Here is you answer from Goodyear;
    Storing Your VehicleWithoutRemovingtheTires
    Ideally, a vehicle in storage should be placed on blocks to remove all weight from the tires. If the vehicle cannot be put on blocks, follow these steps for tire protection:
    • Completely unload the vehicle so that minimum weight will be placed on the tires
    • Inflate tires to recommended operating pressure plus 25%. Ensure that the rim manufacturer’s inflation capacity is not exceeded
    • Be sure the storage surface is firm, clean, well drained and reasonably level
    • Avoid moving the vehicle during extremely cold weather
    • Move the vehicle at least every three months to prevent ozone cracking in the tire bulge area, as well as “flat-spotting” from the prolonged strain of sidewall and tread deflection
    • Adjust inflation before putting the vehicle back into service
    Pero and 2morrow like this.
  11. jimmerheck
    jimmerheck Well-Known Member
    First Name:
    Jim
    Vehicle(s):
    2016 Mustang GT Cal Special
    Jan 10, 2018
    Vancouver, Wa.
    360
    95
    0   0   0
    I think some tires do flat spot. When we bought our Mustang, we also had an Acura TL which was my wifes daily driver. So we kept it for a while as a spare vehicle, the mustang became her daily driver. The Acura had Michelin all seasons on it. The tires on it would definitely flat spot if we didnt drive it for a week or so, but they would get round again after driving the car for around 5 miles. On the Acura forums, other folks also talked about those tires flat spotting. I also have a boat. When I put it away for the winter, I put it up on jack stands and when I turn the tires, you can definitely see the tires are not round, they would not have been turned for a month or so. they have become out of round or flat spotted, but if I go spin them a week later, they have corrected themselves and become round again. Just due to the air pressure in them, 50lbs. These tires are Goodyear endurance radial trailer tires, not junk trailer tires. I think your tires MAY flat spot or go out of round, but I think they may correct themselves after a few miles of driving.
  12. NoVaGT
    Vehicle(s):
    2019 PP1 GT Kona
    Sep 29, 2016
    Northern Virginia
    3,724
    2,308
    Rating:
    100%
    1   0   0
    Think about the age of the tires on the Acura and on the boat trailer.
    Tires that have aged past their date would be far more susceptible to flat-spotting. New tires, not so much. UV light and exposure to the elements ruin tires.
  13. jimmerheck
    First Name:
    Jim
    Vehicle(s):
    Jan 10, 2018
    Vancouver, Wa.
    360
    95
    0   0   0
    The Acura tires were older, low miles, but only half tread, the boat trailer tires are brand new. The Acura tires flat spotted since new (like if we went on a vacation and left it at the airport for 10 days or so.) But you are probably right on older tires for sure.
  14. Triton54
    Triton54 Well-Known Member
    First Name:
    Greg
    Vehicle(s):
    18 GT A-10 (mine) 17 GT pp, 6spd (wifes)
    Dec 19, 2017
    Delano Mn.
    143
    43
    0   0   0
    Actually, thats what i do.....
  15. TheSnowmanMafia
    First Name:
    Andrew
    Vehicle(s):
    2019 GT Premium
    May 26, 2019
    Denver, CO
    196
    75
    0   0   0
    LOL, that is THE answer. Short of moving the car once a month thats how you eliminate the possibility of flat spots in your tires....
Loading...
Share This Page
