How to Retain Handling Without Front Sway Bar
DougS550
Indiana
Doug
2019 GT PP Whipple Stage 2
I have sent them several emails but haven’t ever received a response back. I think there’s definitely a market for this bar especially since I’ve seen so many broken crank snouts lately. Not just on procharger setups either.
Unfortunately we are not “back in the day” and most places won’t touch stuff like this anymore for insurance reasons.
For me, unless I was only going to drag the car, not an issue. But driving on the street with that increase in power, no way Jose’
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I did a quick google and found several fab and welding shops around Tulsa. Call a few one might be willing to do it.
QBailey
QBailey
Tulsa
Quinton
2017 Mustang GT
I have absolutely called and asked for similar things like this to be done, and for insurance reasons been told no.
I am more than capable of cutting up the factory bar and making it work, I just don’t have a way to heat treat it. I don’t think I’d ever trust it fully. It would be my luck I would pitch the car into a turn and load up the suspension, snap the bar and into the ditch I’d go.
Maybe if I hacked up the factory bar to fit and sent it to Steeda they would be more inclined to make one since the hard part is already done. Lol
K4fxd
NKY
I don't see the fuss. After it is fabbed up all one needs to do is take some roll stock and bend it to shape. I don't know if they are heat treated but doing that after the bends should be easy. Steeda welds the end caps so welding shouldn't be an automatic no no.
K4fxd
NKY
I think I'd order some tubing with several bends the diameter I wanted the bar. Then make it fit keeping in mind you want a cnc machine or a hand bender to replicate it.
QBailey
QBailey
Tulsa
Quinton
2017 Mustang GT
I could be making a mountain out of a mole hill. But the risk/vs. reward just isn’t there for me. Especially not on a 1000+rwhp car.
K4fxd
NKY
Corner forces will be the same as stock or close to it.
I wonder if one made it out of two pieces? Anchor the inner end to the frame and the outer to the strut as normal. One on each side, kinda like torsion bars.
There has to be a fabricator who has the knowledge and tools to do this. It's not rocket science.
K4fxd
NKY
I haven't seen the crank support mounted in a car in person so I might be missing something that makes this impossible.
QBailey
QBailey
Tulsa
Quinton
2017 Mustang GT
I’ll try to get some better pictures of one when I’m in the shop next time. It’s not an impossible task it’s just finding some to do it, preferably some who knows more about what they’re doing than I do. Lol
Ewheels
SoCal
Eric
2018 GT PP1, 2020 Explorer, 2023 F150
OP, numerous race cars run without sway bars. They are an easy solution to a problem and do their job well but sway bars are by no means necessary.
You will however need some quite expensive coilovers. I would contact MCS, Penske, Cortex, Kohr, Multimatic, etc to see what they think and if they offer custom packages. You'll likely need some very stiff springs with excellent shock valving but I believe it can absolutely be done.
AZlb5.0
Arizona
Carlos
18 GT Premium
I think that a local shop doesn’t want to take on the responsibility that if let’s say a crash occurs and there’s bodily injury or a death, and it’s found that the sway bar was the culprit of said accident, that the immediate responsibility lies on the operator then befalls on the fab shop.
Experts will get involved and if the shop is found at fault because they didn’t go through the right channels to certify said sway bar fab for street use that shop will more then likely be sued and the owner will lose everything.
bankyf
Fredericksburg, Virginia
2020 Mustang GT Premium PP1
I have heard from multiple people that they don't even notice the swaybar missing on the s550. I stayed with 6 rib on my Whipple so I could run a support and sway bar, but perhaps you should try it without before putting too much effort into a solution. It may be a non-issue on the street (I'm assuming you don't plan to track the car).
QBailey
QBailey
Tulsa
Quinton
2017 Mustang GT
I know, was hoping someone had already went that route and would be willing to share.
QBailey
QBailey
Tulsa
Quinton
2017 Mustang GT
You can definitely tell it’s missing. I’ve done this on a GT350 before and the front definitely has noticeable amount of “roll” in the nose. Definitely not a deal breaker, but also noticeably not factory.
andrewtac
TX
mark
F250. 2020 GT 400A
You can safely drive these without front and back bars at 1k and WOT. The car tracks straight, and I usually leave on some of the nannies on the street. I wouldn't corner hard with, but not sure you'd ever go WOT in a corner with 1k.
