Super Werty
In the middle of the Whipple ten rib install and I'm not sure how to get the alternator pulley off?
I'm slightly confused. I thought the new crank bolt pushed on the damper as you tighten? Why would you need a threaded rod?Yes, a battery impact would also work if you do not have an air compressor. A good 1/2 battery impact would come in handy for suspension work as well as many other things.
I did not use an impact on the crank pulley I purchased a crank installer bolt from MMR and walked it in with a 1/2" long handled ratchet wrench.
If I were to do it again (which I will soon) I'd use a piece of threaded rod because it's long enough to use a washer and a nut so you can turn the nut to essentially pull the balancer on as opposed to pushing it on with a bolt like the MMR.
Did you use this on the crank? To remove or install pulley?Makita 18V 1/2" impact here.
Yep. Also a LSX pulley setup torqued to 220ftlbs.Did you use this on the crank? To remove or install pulley?
The first time I installed the balancer I used the MRR crank bolt. When you align the balancer you start the bolt and when you tighten the bolt it threads itself into the crank and it pushes the balancer on. I believe the MMR bolt I used is designed to work with stock crank pulley not the ATI balancer. The stock pulley is not as deep as the ATI so the bolt just barely grabbed some threads and could have stripped out on me. When I was done the tip of the bolt was stretched out and I wouldn't want to use it again in fear of stripping out the crank threads. I feel I was lucky it didn't happen the first time.I'm slightly confused. I thought the new crank bolt pushed on the damper as you tighten? Why would you need a threaded rod?
