How to protect inside of hood from air box chafing?
dom418
IL
(2) 20 HEP-R, 20 Velocity Blue 350R, 20 Lime 350R
Hi all, I know this is a known issue and I have not seen it on my orange fury R probably due to the lighter color. My performance blue R has 50 miles now and I’m already noticing the damage the air box is doing to the inner hood. I’m hesitant to put PPF in that location due to my fear that the heat may permanently bond the adhesive of the PPF to the hood.
Any other suggestions? Thanks
johnny1
Had new a 16 GT350 and 17 GT350
Thats where the foam gasket on top of air box seals to the hood to keep air from coming in except from the cold air opening in front. I would say just live with it. No matter what you would put up there when you close the hood its still gonna seal against the top of air box like its supposed to and most likely leave a mark.
dom418
dom418
IL
Some have put clear bra in that area but I don’t like the idea of that film being exposed to all of the heat generated from the engine. When you go to remove it, it may cause more damage
nordique14
NorCal
2018 GT350 Magnetic Gray (J1601)
I have used electrical tape. Like the OP, I could see the outline of where the foam rubs on the underside of the hood. I just took electrical tape and covered it up. Prep the area first to promote adhesion. Held up fine for 2 years so far.
luc
CA
2017 GT with PP
PFF will work fine and can take a lot of heat. It’s often time used on the side sills of Viper that have the exhaust and cats running just underneath
Rapid Red
Woodstock GA
Greg
This is the under side of the hood. ?
torque124
Torque
MA
Shelby GT350R
